AR3201 Harness?
Old March 6th 09, 03:30 PM posted to rec.aviation.soaring
Soarin Again[_2_]
Default AR3201 Harness?
At 13:58 06 March 2009, cemx86 wrote:
Finally, you need to get your work inspected and signed off by an FAA
licenses tech. This is a given for standard certified aircraft. But is
also a requirement for experimental certified aircraft, unless you built
51% of your glider, which seems kinda doubtful.
My $0.02
While it might be a good idea to have a mechanic look at the wiring. But
where do you get the opinion from, that an FAA licensed airframe mechanic
is required to sign off re-wiring on an Experimental glider?
looking for Hooker harness Al MacDonald Home Built 0 July 12th 08 03:54 PM
Wanted: Becker AR3201 Ira Blieden Soaring 0 December 14th 06 06:28 PM
Looking for a Becker AR3201 Ira Blieden Soaring 0 December 8th 06 01:38 PM
S-H safety harness (V2C) [email protected] Soaring 20 April 28th 06 08:54 AM
Harness Nolaminar Restoration 2 December 25th 03 03:04 PM
