On Mar 14, 9:56*pm, Brian Whatcott wrote:
wrote: ------------------------------------------------------- What's the mission? Are you fueling an ultralite? In flight transfer of fuel from aux tank to main header tank in a Bowers Fly Baby. That suggests a minimum transfer rate of a pint a minute would be needed to keep up with the greatest conceivable flow - but a gallon a minute would do nicely? Brian W Header tank is 16 gal. After that has gone down to 10 the aux fuel can be sent to it. That allows approximately 2 hours to transfer the 6 aux gallons to the main (allowing for half hour reserve). Not that I want to do it that slowly. Actually, for optimal CG it would be nice to send the aux up when the main is down to reserve so that would require a much faster rate. |
In flight transfer of fuel from aux tank to main header tank in a Bowers Fly Baby. Do you have an electrical system? If so how about one of the "clicker" pumps like the Cherokee uses. They are made in uncertified versions that are quite cheap. The Ercoupe O-200 engine installation STC uses one of the uncertified versions to pump from the wing tanks to the header tank. If you have C-75 or 85 why not fit an engine driven pump? Cheers: Paul N1431A KSDM |
On Mar 15, 11:49*am, "Tri-Pacer" wrote:
In flight transfer of fuel from aux tank to main header tank in a Bowers Fly Baby. Do you have an electrical system? If so how about one of the "clicker" pumps like the Cherokee uses. They are made in uncertified versions that are quite cheap. The Ercoupe O-200 engine installation STC uses one of the uncertified versions to pump from the wing tanks to the header tank. If you have C-75 or 85 why not fit an engine driven pump? Cheers: Paul N1431A KSDM electrical system is gel cell. Engine is A75 Thinking about this pump. Half a pound and $35 http://www.sigmfg.com/cgi-bin/dpsmar...883.html?E+Sig |
| Thread Tools | |
| Display Modes | |
| Fuel transfer pump | rmhou at yahoo.com | Home Built | 8 | August 20th 07 02:35 AM |
| Trailer tow vehicle fuel pumps | Steve Leonard | Soaring | 2 | March 4th 07 10:35 PM |
| Trailer tow vehicle fuel pumps | Bill Daniels | Soaring | 15 | March 4th 07 04:59 PM |
| Anybody need a fuel transfer pump? | Roy Smith | Home Built | 1 | January 5th 04 06:53 PM |
| Fuel Transfer Placards | Ben Smith | Owning | 22 | October 16th 03 03:32 PM |
