On Mar 22, 5:23*pm, AK wrote:
I want to make a small mold I would later use to create a fiberglass container to hold lead weight. It would be nice if *mold material can withstand 500 degrees Fahrenheit so I can pour lead into it and then cover it by fiberglass. Alternatively I would use the mold to create a fiberglass container first and fill it up with lead pellets. So my question is what do I use to make a mold, gypsum if so what kind, anything else? Andrzej sand |
On Mar 23, 8:28*am, wrote:
On Mar 22, 5:23*pm, AK wrote: I want to make a small mold I would later use to create a fiberglass container to hold lead weight. It would be nice if *mold material can withstand 500 degrees Fahrenheit so I can pour lead into it and then cover it by fiberglass. Alternatively I would use the mold to create a fiberglass container first and fill it up with lead pellets. So my question is what do I use to make a mold, gypsum if so what kind, anything else? Andrzej sand http://en.wikipedia.org/wiki/Sand_casting not quite that simple in practice and would also req the purchasing of some specific setup materials which are not found at Home Depot etc... You should go the wood or plaster route.Wood is dead simple if your shape is not to complex. I saw that Steve quite rightly mention of worry of plaster and residual water/steam being an issue... hence the very specific directions I layed out for preheating/drying your plaster mold BEFORE lead is poured in. If it survives the 4 hr incremental ramp up to 400deg, it will not break from the pour since all the water will have been evacuated by then. If in doubt, leave it in the oven for an extra hr or 2 at 400ish... I dabble in investment casting, and the same methodology applies for pouring 1700-2100 deg metal (bronze, slver, gold, etc) into a plaster mold, except the heatup/dryout process brings it up to 1000deg over a 5, 7, or 12 hour ramp up (usually spending some an hr or 2 at 1300deg to vaporize out the wax remnants before ramping back down to 1000ish). -Paul |
On Mar 23, 12:12*pm, sisu1a wrote:
On Mar 23, 8:28*am, wrote: On Mar 22, 5:23*pm, AK wrote: I want to make a small mold I would later use to create a fiberglass container to hold lead weight. It would be nice if *mold material can withstand 500 degrees Fahrenheit so I can pour lead into it and then cover it by fiberglass. Alternatively I would use the mold to create a fiberglass container first and fill it up with lead pellets. So my question is what do I use to make a mold, gypsum if so what kind, anything else? Andrzej sand http://en.wikipedia.org/wiki/Sand_casting* not quite that simple in practice and would also req the purchasing of some specific setup materials which are not found at Home Depot etc... You should go the wood or plaster route.Wood is dead simple if your shape is not to complex. * I saw that Steve quite rightly mention of worry of plaster and residual water/steam being an issue... * *hence the very specific directions I layed out for preheating/drying your plaster mold BEFORE lead is poured in. If it survives the 4 hr incremental ramp up to 400deg, it will not break from the pour since all the water will have been evacuated by then. *If in doubt, leave it in the oven for an extra hr or 2 at 400ish... I dabble in investment casting, and the same methodology applies for pouring 1700-2100 deg metal (bronze, slver, gold, etc) into a plaster mold, except the heatup/dryout process brings it up to 1000deg over a 5, 7, or 12 hour ramp up (usually spending some an hr or 2 at 1300deg to vaporize out the wax remnants before ramping back down to 1000ish). -Paul Thank you a lot to all who responded, especially to Paul for the details he provided and Steve for the safety warning. I was already aware of safety issue, but I appreciate you mentioned it. |
Lyc IO-540 won't make RPM. | [email protected] | Owning | 12 | December 14th 06 10:21 PM |
How did he make this joint? | Michael Horowitz | Home Built | 4 | September 16th 05 06:14 PM |
Fiberglass / Mold release advice requested | Mark Zivley | Home Built | 10 | April 2nd 04 11:15 PM |
How much does a CFI make? | Peter Gibbons | Piloting | 27 | August 17th 03 02:48 AM |
$$$'s make right? | Sydney Hoeltzli | Piloting | 9 | July 15th 03 04:54 AM |
