On 24 Mar, 23:20, AK wrote:
On Mar 24, 12:24*pm, The Real Doctor wrote: It might be worth thinking about using plumber's solder instead. It's a lead-tin eutectic alloy, which means it melts at a significantly lower temperature (183 degrees C), but still has a high density (84% that of lead). Do you know of good source for this alloy (I don't know if I want to go to Radio Shack to buy 40 lb of solder? My wallet would be way too light and then I would have to buy even more of the alloy. Builders' merchants used to sell it by the kilogram, but it's banned or about to be banned for domestic use so may be harder to find in the UK now. Dunno about where you are. Ian |
Lyc IO-540 won't make RPM. | [email protected] | Owning | 12 | December 14th 06 10:21 PM |
How did he make this joint? | Michael Horowitz | Home Built | 4 | September 16th 05 06:14 PM |
Fiberglass / Mold release advice requested | Mark Zivley | Home Built | 10 | April 2nd 04 11:15 PM |
How much does a CFI make? | Peter Gibbons | Piloting | 27 | August 17th 03 02:48 AM |
$$$'s make right? | Sydney Hoeltzli | Piloting | 9 | July 15th 03 04:54 AM |
