cobra trailer brake lever gas strut failure?
Old March 31st 09, 02:38 AM posted to rec.aviation.soaring
Frank[_1_]
Default cobra trailer brake lever gas strut failure?
It appears that the gas strut on the brake lever of my cobra trailer
has failed. Today I noticed the lower end was no longer connected
(apparently the bottom pin detached from the fixed connection point),
and it was just hanging loose by the top connection. In addition, the
strut seems jammed in the extended postion. It rotates ok (with a
little resistance) but won't collapse any, even with a *lot* of
pressure.
Any advice for repair/replacement? Is this a cobra-only part, or will
any gas strut of the same length and throw do the job? Is the cobra
part available at finite cost?
TIA,
Frank (TA)
Older Cobra trailer brake oscillation Brian Bange[_2_] Soaring 9 March 10th 09 08:41 PM
Cobra Tongue Strut Removed Finally Brian Iten Soaring 0 December 4th 04 08:54 PM
Cobra Trailer Strut Help Please.... Brian Iten Soaring 4 November 30th 04 05:15 PM
Cobra Brake Parts or Axle WDM Soaring 1 October 11th 04 06:09 AM
Komet trailer strut John Shelton Soaring 5 November 15th 03 06:04 PM
