Hi,
1. Fertig (Ready, the pilot is ready to be launched.) 2. Seil straff (All of the slack is out of the cable) 3. Frei (The glider has cleared the ground) The official standardized phraseology as laid down in the SBO (Segelflugbetriebsordnung)[1] is: 0) Inform the winch driver about type of glider, seats taken, ballast, anything that may affect his choice of power to be applied. Also information about things like plans for a simulated cable-break. And on multi-drum winches identification of the cable being used. "Am Bonner Seil eine ASK-21, doppelsitzig, startklar." 1) "Seil anziehen". 2) When all slack is taken up: "Seil straff". At this point we release the brake on our winch but do not apply any power above idle. 3) When the glider starts rolling: "Fertig". This is the point where launch power is (smoothely) applied. This is not necessarily full power, depending on winch, aircraft and conditions like wind. 4) "Frei" as the glider leaves the ground. After this point the winch driver can see the glider. At any time "Halt Stop! Halt Stop! Halt Stop!" to abort. These commands were relayed to the winch operator via a "field telephone", the kind where you would turn the little crank to ring the bell on the other end of the line. It is also required that there is a _reliable_ (emphasis from the SBO) voice-link between the launch point and the winch. Using aircraft radio/frequency is explicitly disallowed. So it usually is a fixed telephone line. Ciao, MM [1] http://www.daec.de/se/downfiles/SBOstand01-11-2008.pdf |
patent for bank angle from GPS signals | Tony | Piloting | 7 | February 7th 07 12:25 AM |
Tow Signals | Ramy | Soaring | 58 | October 19th 06 04:46 AM |
Glider - Towplane Signals | Mike the Strike | Soaring | 24 | March 26th 05 09:33 PM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
The wrong signals to send to young visitors. | Larry Dighera | Piloting | 57 | November 26th 03 07:05 AM |
