I am trying to find (remember) the standard formula for tow pressure on the
tow line in a standard smooth tow. I forget if it is weight of the glider divided by L/d or a percentage of L/d. Initial tow pull to get rolling, is high drag on the line. I can tell when the skid comes up on the 2-33 or when the 2-33/Grob/Janus break ground. The reduction in rolling resistance can be felt in the tow plane, even on a paved runway. We never notice a 1-26 on tow. Unless the weak link has been further weakened by use, we normally don't break the link for training slack line recoveries. We have a Standard Schweizer tow set up on our Pawnee and it is placarded to 1200# Max. Our weak links are to the about the 1000# configuration to fit the 80-200% CFR requirement for most of our gliders. We routinely tow one glider at about 1500# with no issues. This glider POH specifies a weak link tolerance higher than our standard links and CFRs. We have a special weak link for that one and still stay within the 1200# max. Yes the Tow rating is limited to being able to effect a release if it had the max pressure holding mechanism, as in the case of the glider kiting and lifting the Pawnee tail. B "150flivver" wrote in message ... On Apr 13, 8:01 am, wrote: The basis of this specification, if I recall correctly, was force on the release handle. Rope strength is specified with limits related to the max certified gross weight of the glider being towed, that is NTL .80 of gross wt and NGT than 2.0 times gross wt. Weak links can be used, as appropriate to saty within these limits. If the approved installation of the tow hook has other limits, they are in addition to those related to the glider defined limits. If you are using a hook not produced for towing gliders(there are lots of home made banner towing hooks made to AC 43-13 which may not be suitable for glider towing), consider moving to a proven tow hook installation. Good Luck UH So in your example, a Schweizer hook is limited to 1200 lbs and it would be acceptable to tow a 1500 lb glider as long as the rope (or weak link setup) was rated at 1200 lbs? Unfortunately, the wording on the placard doesn't refer to rope strength limits, but to maximum glider weight. If it referred to rope strength, I could see it being legal to tow a 1500 lb. glider by using a 1200 lb setup but because it specifies a max gross weight for the glider/banner, wouldn't anything heavier exceed the legal limit? |
the max pressure holding mechanism, as in the case of the glider kiting and lifting the Pawnee tail. I can't remember the name of the company right now, but they are making SGS style tow hooks that will release under considerably more pressure than std SGS hook. It has precision bearings in it where the SGS is just plain metal on metal so the release friction is reduced by multitudes of force. -Paul |
On Apr 13, 8:06*pm, sisu1a wrote:
Yes the Tow rating is limited to being able to effect a release if it had the max pressure holding mechanism, as in the case of the glider kiting and lifting the Pawnee tail. I can't remember the name of the company right now, but they are making SGS style tow hooks that will release under considerably more pressure than std SGS hook. It has precision bearings in it where the SGS is just plain metal on metal so the release friction is reduced by multitudes of force. -Paul well Spruce has'm but they're not STC'd... (hook at bottom of page) http://www.aircraftspruce.com/catalo...towBanners.php -Paul |
On Apr 14, 2:23*pm, "BT" wrote:
I am trying to find (remember) the standard formula for tow pressure on the tow line in a standard smooth tow. I forget if it is weight of the glider divided by L/d or a percentage of L/d. Well, yes, for straight and level flight at constant speed it would be the weight of the glider divided by the L/D of the glider at that speed. So if it's 400 kg and 40:1 then the tow force is 10 "kg" (not a proper SI unit of force), or about 100 N. But if you're climbing then you also need to look at the climb angle. Technically you'll want the sine of the climb angle times the weight of the glider but for real world tugs it'll be plenty close enough to use: (rate of climb / tow speed) * weight of the glider Making sure of course that the first two are in the same units e.g. both in knots or both in fpm or whatever. So, for example if you tow the above 400 kg glider at 70 knots at a rate of climb of 700 fpm (7 knots) then you've got another 40 kg or 400 N of tension on the rope from that, for a total of 50 kg of tension. Plus, as you point out, if you're accelerating then you need to take that into account as well, but once you're into a steady climb you're obviously not. |
Fiberglass cloth weight vs 'finished' weight | Fred the Red Shirt | Home Built | 12 | April 5th 08 04:24 PM |
Glider Weight/Wing Loading and determing speed for best L/D for a given weight | 65E | Soaring | 3 | January 26th 06 09:26 PM |
ILS DME strength? | Jim Burns | Instrument Flight Rules | 10 | November 2nd 05 11:10 PM |
Tubing strength | Ernest Christley | Home Built | 0 | January 16th 04 11:43 PM |
Empty/Gross weight Vs. Max. Pilot weight | Flyhighdave | Soaring | 13 | January 14th 04 04:20 AM |
