ATC Radar Question
Old June 13th 09, 06:09 AM posted to rec.aviation.piloting
Jackie
Default ATC Radar Question
Matt Barrow wrote:
"Jackie" wrote in message
I understand that ATC radar uses an encoding altimeter and a transponder
operating with Mode C to determine an aircraft's altitude. Let's forget
about Mode C for a moment and switch to Mode A only or just a primary
return.
If an aircraft is at 18,000 ft (approx 3 nm) and 3 nm away from the radar
antenna, as seen on a map, how does the radar correct for slant distance
when distance is displayed (e.g. using concentric circle distance markers on
the scope or relative to a known distance, such as a marker on the display)?
In other words how does the radar know that the aircraft is actually 3 nm
away laterally and not 4.25 nm (approx slant distance at that altitude)?
Asquared + B squared = C squared, I'd guess.
And how does it separate A and B?
"A" is the radar range, "B" is garnered from the encoding altimiter.
Huh? In the example I provided, "Let's forget about Mode C for a moment
and switch to Mode A only..." there is *no encoding altimeter* so your
point doesn't make sense here.
Old June 13th 09, 06:18 AM posted to rec.aviation.piloting
John Clear
Jackie wrote:
That's interesting. So if what you say is correct, an airport
surveillance radar has very little coverage of the area, say at the top
of a class B airspace because to cover that high an angle is "wasteful."
For example, a VFR plane flying legally just above the B ceiling could
very well be out of coverage of the radar that is supposed to be also
monitoring another high performance aircraft poking through that ceiling
at a high rate of speed. I'm not sure I agree with such an energy
saving measure.
Over the top of a class B airport is where the planes taking off
from that airport usually aren't. They go out the sides, not
straight up. There is usually more then one radar feed for a
TRACON, so although the radar at the primary airport for the class
B can't see right above it, other radars in the area provide that
coverage.
For example, SFO has a radar station, as does OAK and NUQ (Moffett
Field). They overlap each other so there is fairly complete
coverage.
John
John Clear - http://www.clear-prop.org/
Old June 13th 09, 03:19 PM posted to rec.aviation.piloting
Brian Whatcott
Jackie wrote:
Brian Whatcott wrote:
radar antenna, as seen on a map, how does the radar correct for slant
distance when distance is displayed (e.g. using concentric circle
distance markers on the scope or relative to a known distance, such
as a marker on the display)?....
I am late into the thread.
But you are presumably talking about an area surveillance radar.
Its fan beam does not typically stick 45 degrees up into the sky. Too
wasteful of energy.
saving measure.
Another concept to ponder: if its beam WERE able to steer up at 45
degrees or more, what do you think its path would look like on a plan
position indicator? (a regular display). You've mentioned its slant
range is 4.25 miles at 3 mile distance horizontally. 30 seconds later,
it might be overhead: where would it paint in terms of range?
Three miles?? A circular range ring at 3 miles, all round the display?
My distances where small to keep the math simple for discussion
purposes, not to suggest what an actual display would include. Geez.
Your understanding of the concept of airfield control radars and
surveillance radars is incomplete.
At a particular airfield the area of most interest is the approaches,
and potential conflicts. High flying traffic is of no interest.
The range limit of airfield radars may be in the 30 mile radius range.
If you work out the antenna angle needed to view an aircraft at 10,000ft
at 30 miles, you will see that the desired angle is not large. (4 deg)
The beam's vertical fan may be as low as 5 to 10 degrees.
But this is tiltable.
Area surveillance radars do not operate typically as singletons.
They look much further. They work with secondary transponders.
Brian W
Old June 14th 09, 01:09 AM posted to rec.aviation.piloting
Jim Logajan
transponder operating with Mode C to determine an aircraft's
altitude. Let's forget about Mode C for a moment and switch to
Mode A only or just a primary return.
slant distance when distance is displayed (e.g. using concentric
circle distance markers on the scope or relative to a known
actually 3 nm away laterally and not 4.25 nm (approx slant distance
at that altitude)?
Nit: Actually "C" would be radar range and either "A" or "B" would be from
the altimeter, solving then for "B" or "A".
Old June 15th 09, 12:29 AM posted to rec.aviation.piloting
BT
It does not correct.. Radar Range is slant range.. so using RAW Radar and
Skin Paint.. or even a Transponder Mode3 only, 4 codes, you will get a ring
around the mainbang (radar location) as the aircraft approaches the radar
site. It may disappear if smack on directly overhead until exiting the donut
hole on the other side.
I believe even Mode3C with digital displays have the same problems, but with
extensive radar coverage in most areas, the digital display is a mosaic
display of multiple radar feeds with the best target for a given location
coming from a certain radar. So another radar will "paint" the area over the
"mainbang" of the other radar.
This does not always happen depending on multiple radar coverage available.
BT
return.
on the scope or relative to a known distance, such as a marker on the
display)?
Old June 15th 09, 12:32 AM posted to rec.aviation.piloting
BT
I don't think that altitude from the ModeC is ever factored into where to
plot the target. The target was always slant range.
BT
distance markers on the scope or relative to a known distance, such as
Without altitude information from the pilot or a Mode C transponder, the
radar system can't extract the horizontal distance from the slant
distance. Where did you read that their systems correct for altitude
without Mode C transponders? If they could do that then they wouldn't
have ever needed the transponders to report altitude.
So if a pilot turns his Mode C from off to on, does the radar then correct
the distance plotted (less distance from the antenna) based on the
altitude reported?
Old June 15th 09, 12:33 AM posted to rec.aviation.piloting
BT
and that has nothing to do with Mode C accuracy
"Matt Barrow" wrote in message
"Stealth Pilot" wrote in message
On Fri, 12 Jun 2009 03:54:29 +0000 (UTC), Clark
Jackie wrote in
[snip]
Does precision approach radar require a transponder to report altitude?
PAR uses a height finder radar to provide sufficient vertical resolution
for
precision approaches.
Mode C only provides 100 foot altitude resolution. bzzzzt!
Mode C provides a height eg 1252ft which is deemed only accurate to
100ft because the calibration errors are limited to 100ft.
And when local BARO is not available, the minimums go up.
And why the slop (calibration error) is taken into account when developing
approach procedure.
  #28
Old June 15th 09, 12:34 AM posted to rec.aviation.piloting
BT
reported altitude from a ModeC transponder is never used for vertical
guidance on a PAR approach.
Jim Logajan wrote:
radar
distance
markers on
distance.
Where did you read that their systems correct for altitude without Mode
C
transponders?
I don't believe I indicated I read this.
If they could do that then they wouldn't have ever needed the
At the altitudes involved during approach, it's not so critical (altitude
is, but not the angle), but during
approach the heading data is as critical as the altitude reporting.
  #29
Old June 19th 09, 10:31 PM posted to rec.aviation.piloting
Mike
"Clark" wrote in message
"Morgans" wrote in :
"Bob Noel" wrote
the elevation radar determines altitude the same way the azimuth radar
determines bearing.
There are actually two radars running for PAR, right? One sweeping left
to right and one sweeping up and down, I think.
As far as I know you are entirely correct. The installations I've seen
(years
ago and far away) have two independent radar systems, one for the
horizontal
and one for the vertical. Of course I've only seen ancient technology and
I'm
sure that these days it could be done with one steerable beam.
Older PARs (which there are many still around) don't really have two
independent systems. They basically separate the radar signal between two
antenna (one for azimuth and one for elevation). Newer designs (which are
still quite old) use a phase array which steers the beam. In both designs
the transponder is neither required or used.
  #30
Old June 19th 09, 10:45 PM posted to rec.aviation.piloting
Mike
return.
display)?
It's pretty simple. The radiated energy from the transmitted pulse takes
12.36 microseconds to travel one mile and back. The radar uses that timing
to determine range. No corrections for altitude are made. The system that
receives transponder signals (which is an independent system which is
correlated later) works exactly the same way.
below the radar Philip Stroh Aviation Photos 31 November 27th 06 03:12 PM
Integrating onboard weather radar data with satellite-fed Doppler radar [email protected] General Aviation 3 January 9th 05 08:57 PM
Question about the F-22 and it's radar. Scott Ferrin Military Aviation 128 June 13th 04 01:23 AM
Yet another "Radar Required" question. Roy Smith Instrument Flight Rules 14 April 27th 04 05:07 PM
F15E Radar question. Bill Silvey Military Aviation 5 August 30th 03 06:17 PM
