Moisture in Winter Vario
Old June 23rd 09, 03:25 AM posted to rec.aviation.soaring
Gary Emerson
Default Moisture in Winter Vario
Roy Bourgeois wrote:
Wayne:
Remove the glass front (there are notches in the bezel that will fit
either 2 screwdrivers or the special tool that is used for this) then put
the unit in your kitchen stove on "warm" (not more than 175F) for 2
hours. Then reassemble.
Roy
At 00:46 23 June 2009, Wayne Paul wrote:
I have a HP-14 which is kept assembled and tied down on the ramp. This
has never been problem until this Spring. (There has been far more rain
then normal this year.) =20
When flying last Friday I noticed water droplets on the inside of the =
Winter mechanical vario lens and the instrument was erratic when =
compared to the electronic vario. Since I landed the Winter's needle =
has indicated 1/2 kt down.
The instrument panel has been removed and the total energy system =
purged. How do I get the moisture out of the Winter Vario?
http://www.soaridaho.com/
If you have a hack saw blade and a grinder you can make a tool for the
notches in the bezel holder which will work lots better than two
screwdrivers. Cut the blade about 2" longer than the instrument is in
diamter and then grind back the outer 1" so that the center section will
drop down into the notches without hitting the ID of the threads. Takes
only a few minutes and definitely worth the effort.
Winter mechanical vario Brian Bange[_2_] Soaring 1 February 15th 09 12:53 AM
Winter Vario # 5493 Tim Mara Soaring 0 June 15th 08 02:22 PM
Winter Vario # 5493 [email protected] Soaring 5 June 15th 08 02:11 PM
Looking for used SN-10 and Winter Vario Pov Soaring 0 October 8th 06 07:38 PM
Winter Vario [email protected] Soaring 2 August 17th 05 08:24 AM
