Clearance on hold, hold for release
Old June 24th 09, 03:16 PM posted to rec.aviation.piloting
Mike Granby
Default Clearance on hold, hold for release
Further to this, I found this in the ATC manual...
http://www.faa.gov/airports_airtraff...atc0403.html.1
"Hold for release" instructions shall be used
when necessary to inform a pilot or a controller
that a departure clearance is not valid until
additional instructions are received.
While it's grouped together with void times and other techniques used
at non-towered airports, there's nothing in there at explicitly says
it can't be used to indicate an incomplete clearance at a towered
field. Still it's awfully misleading. "I'll get back to you with the
beacon code" would have been a lot clearer!
Don't hold a investment! Admiral D. K. Sligh Piloting 0 August 14th 07 05:29 AM
Hold at VOR for 2v2 Doug Instrument Flight Rules 21 May 27th 04 11:42 PM
where can i get hold of a current map? Taz H Soaring 5 April 22nd 04 02:17 PM
where can i get hold of a current map? Taz H Soaring 4 April 22nd 04 07:59 AM
Hold "as published"? John Clonts Instrument Flight Rules 83 November 13th 03 03:19 PM
