I've endured l-o-o-o-n-g rigging sessions with both a family HBV
(Libelle 301 wings) and a friend's 16.5 meter Diamant. In both cases the problem was operator error. The HBV is almost as easy as a 301 except you can't see what's happening inside the fuselage. And if you rig the wrong wing (R, I believe) first in defiance of the owner's manual, the flap drive will jam and prevent your getting the other wing on. The long-wingers are much heavier but no more complex. IIRC, a few people had problems with the socket in the L wing into which a pin from the right wing spar is inserted. The socket is a floating, slightly tapered bushing and I think it can rotate 180 degrees, making it impossible to plug the spar pin into the small end of the bushing. This is probably more than you want to know about either type. Basically the long wingers are MUCH heavier and you've gotta have good wingstands or very strong assistants. But both types assemble fairly easily if you know what you're doing. The horror stories began, I think, because many of the early owners didn't know much about rigging these fairly early fiberglass gliders. Chip Bearden ASW 24 "JB" USA |
| Thread Tools | |
| Display Modes | |
| Diamant 16.5 Part Out... | [email protected] | Soaring | 3 | October 7th 18 09:36 PM |
| Do you assemble your glider paying good attention to it? | [email protected] | Soaring | 6 | January 24th 07 11:48 AM |
| Do you assemble your glider paying good attention to it? | Steve Leonard | Soaring | 0 | January 23rd 07 01:53 AM |
| Diamant 18m | phil collin | Soaring | 6 | March 29th 06 10:02 PM |
| A&P signoff required to re-assemble 1-26? | [email protected] | Soaring | 5 | July 13th 05 06:32 PM |
