I very much appreciate all the members response. Since originally
posting, a similar IFR trip occurred from the same field. Different controller, though. This time after hearing "readback correct" from Clearance Delivery, I received the departure frequency, and was told clearly I'd get the squalk when holding ready for takeoff. I then said "ready to taxi" and was cleared to the active. Holding short lasted almost 45 minutes anyway, it was a low ceiling day, and even though there were only two other aircraft waiting for IFR release at our field, a number of local airports are combined as far as ATC is concerned for IFR traffic and we simply had to wait our turn. During IFR training (at different airport) ATC used what the CFII called a 'gate hold' ; for a period of expected delay after clearance approval but before taxi. Engine start could then be offset that amount of time to save fuel and reduce rwy/taxiway congestion. We stayed in the parking spot until told to contact ground to taxi. It's still teamwork though, pilots and ATC, and thanks to the feedback here the next time will be more informed, and safer. Thanks! |
"Hap" wrote in message
... I very much appreciate all the members response. Since originally posting, a similar IFR trip occurred from the same field. Different controller, though. This time after hearing "readback correct" from Clearance Delivery, I received the departure frequency, and was told clearly I'd get the squalk when holding ready for takeoff. I then said "ready to taxi" and was cleared to the active. Holding short lasted almost 45 minutes anyway, it was a low ceiling day, and even though there were only two other aircraft waiting for IFR release at our field, a number of local airports are combined as far as ATC is concerned for IFR traffic and we simply had to wait our turn. During IFR training (at different airport) ATC used what the CFII called a 'gate hold' ; for a period of expected delay after clearance approval but before taxi. Engine start could then be offset that amount of time to save fuel and reduce rwy/taxiway congestion. We stayed in the parking spot until told to contact ground to taxi. It's still teamwork though, pilots and ATC, and thanks to the feedback here the next time will be more informed, and safer. Thanks! That "gate hold" is the only thing that I had ever experienced while riding along--as I have never been close to an instrument raing personally. However, that was Pre-ElizabethDole. |
Don't hold a investment! | Admiral D. K. Sligh | Piloting | 0 | August 14th 07 05:29 AM |
Hold at VOR for 2v2 | Doug | Instrument Flight Rules | 21 | May 27th 04 11:42 PM |
where can i get hold of a current map? | Taz H | Soaring | 5 | April 22nd 04 02:17 PM |
where can i get hold of a current map? | Taz H | Soaring | 4 | April 22nd 04 07:59 AM |
Hold "as published"? | John Clonts | Instrument Flight Rules | 83 | November 13th 03 03:19 PM |
