Hmmmmm.
I own (or should I say my Son's now own as they generally fly it now days as I have another toy to play with) a Diamant 17.2 It started life as a 16.5 and was the "first Glass Glider" in Australia and first flew in Australia in November 1967. Serial number 018. It was first owned by Malcolm Jinx who went on to win the nationals in it that year and the following 2 years against Open Libelle's and Kestrel 17's. In 1968 it had 'Factory" wing tip extensions fitted taking it to 17.2mts. I have owned the aircraft since 1981 and love the old girl. My best flight in it was 720kms and cut short due to a late start and failing conditions. Not bad for an old bird. Soars like wood and cruises like glass. Gets you home at the end of the day when other ships can't stay up. Long legs and great soaring. Have noted the comments on the rigging. Our wings are 100kgs each and the fuse is 101kgs. The wings are like rigging a Twin Astir really. Yep they are heavy. Some have mentioned right wing first but I want to point out the big advantage is when it is plugged in, the stub pin sticks out and you can see it to be able to guide the left wing onto it rather than the reverse where it is then blind. I find with a couple of helpers it is over in about 5 mins if you know what you are doing. As far as maintenance goes I don't understand the suggestion there might be a problem. From my perspective there is only 1 recurring AD (Elevator Push Rod Fork) and an easy inspection. The access holes in the wing ( six in each) make it one of the easiest gliders I have ever found for wing inspection and maintenance of control system bearings. I find it a breeze compared to many aircraft I work on. Value wise depends on what you pay of course. I tired to sell it some years ago when I upgraded. I couldn't get a decent offer so thought blow it the boys can have it. When the second went Solo I did the annual and got it back in the air. For both of them it was their second Solo machine. It is that easy to fly. The youngest got into it at 15. Of course they were groomed for it thus prepared but still it is easy. No vices to speak of. With an LS4, LS7 and Discus in the club fleet they are still happy to fly the Diamant. It is unusal but I wouldn't call it a Dog. If your friend can get into it at a reasonable price and get a lot of use out of it good on him. For me I reckon I got my moneys worth years ago (gold and diamond) and now the next generation can. I don't count the cost. Comes down to perspective. I reckon it's good for 850k over here and reckon Son number 2 might well prove me right one day. Cheers Nige. At 04:53 27 June 2009, wrote: The FFA 16.5 Diamant was the first "All plastic" aircraft, ie, all man made composite structure. There is no balsa, or any wood anywhere in the ship, and metal parts are very limited to control system and gear. It is a very elegant design for it's day, but had serious quality problems during manufacture of the composite parts. The wing and the ship is very heavy by current standards, but nothing the right set of dollies won't fix. By dollies I mean two sawhorses and a root dolly, Any two piece wing is a cinch to rig if you balance the wing weight on sawhorses or dollies and lower the fuse cradle with an electric jack. Once you buy one, you will probably won't be able to sell it. if a ship was considered a dog 25 years ago it does not get a pedigree because it got older. However, it flies great and if you have to buy an albatross, you could do worse. if you are a engineering student on a budget and want to trade even for say, a Cherokee, it would be a great choice. Educate yourself with all the AD's and SB's, and maintenance records, and definitely fly before you buy. Reclining seat position is a problem for some folks, as is the canopy mechanism. Any oddball 40 year old ship will have problems, if one is buying it because the price is right you are going to be in for a rude surprise. MM Former owner, D 16.5 s/n 44 |
Diamant 16.5 Part Out... | [email protected] | Soaring | 3 | October 7th 18 08:36 PM |
Do you assemble your glider paying good attention to it? | [email protected] | Soaring | 6 | January 24th 07 10:48 AM |
Do you assemble your glider paying good attention to it? | Steve Leonard | Soaring | 0 | January 23rd 07 12:53 AM |
Diamant 18m | phil collin | Soaring | 6 | March 29th 06 09:02 PM |
A&P signoff required to re-assemble 1-26? | [email protected] | Soaring | 5 | July 13th 05 05:32 PM |
