Sent: Saturday, July 04, 2009 4:28 AM Newsgroups: rec.aviation.homebuilt Subject: How Much Load for a Load Test? AC weight - wing weight cause wing is supported by the air in real flying so G's will not load the spar, then multiply by G's _then_; subtract the weight of the wing, since gravity is pulling on the wing in the load test, so you can take that many bags bags off. (since gravity is doing 200 pounds of the work for you) So, I'm flying along in flight and I roll inverted and pull through to the vertical. The ground's coming up fast and I pull to recover. The wing's weight is towards the nose. How hard can I pull? If I designed to this criteria I can't pull four Gs. I didn't test to four Gs. Why do you call this a four G wing? Rich Isakson |
![]() "Richard Isaksom" wrote in message ... So, I'm flying along in flight and I roll inverted and pull through to the vertical. The ground's coming up fast and I pull to recover. The wing's weight is towards the nose. How hard can I pull? If I designed to this criteria I can't pull four Gs. I didn't test to four Gs. Why do you call this a four G wing? Rich Isakson I am, of course, wrong here. The discussion is about testing with the wing mounted upside down in a fixture so the wing weight would be credited as part of the lift. Rich Isakson |
Get a Load of This | [email protected] | Soaring | 4 | December 3rd 07 06:04 PM |
Raise your useful load without an STC... | Hilton | Piloting | 13 | August 5th 07 02:15 AM |
Server over-load | Jim Macklin | Piloting | 6 | August 17th 06 01:48 AM |
New 182T, where's the useful load?? | Robert M. Gary | Piloting | 10 | April 27th 06 06:48 PM |
What's your maximum G-load? | Happy Dog | Piloting | 13 | July 4th 05 03:46 PM |
