Continental A-65 engine stall?
Old July 13th 09, 11:47 AM posted to rec.aviation.homebuilt
Scott[_7_]
Default Continental A-65 engine stall?
Bob wrote:
To All:
Annd if
you've done like most of us and wrapped an over-stretched screen-door
spring around the exhaust stack, odds are it rusted itself into FOD
during the Eisenhower administration.
-R.S.Hoover
Yes, I was concerned about the doorsprings corroding and breaking pieces
off to be ingested into the carburetor since there isn't any sort of
filter in the "warm" air path between the heat muff and the carb airbox...
One thing that is different on my system now (since my recent top
overhaul) is the addition of an air inlet on the engine baffle between
the nosebowl and the cylinder (pilot side) with tubing running from it
to the heat muff. My old system just had the inlet pipe of the Aeronca
heat muff unconnected to anything and I noticed that the aluminum heat
muff looked like it had melted a bit where it was contacting the exhaust
pipe so I added the cool air inlet to help cool the heat muff a bit.
Maybe it cools it too much and I'm just not getting enough heat, so
increasing the surface area sounds like a good idea...just unsure of the
method. I know I DO NOT want FOD running into the carb as that is SURE
to cause the engine to react [not so] funny
Scott
Old July 13th 09, 08:22 PM posted to rec.aviation.homebuilt
Anthony W
A stainless steel screen should be a standard item over the air intake
on any engine if you are running without a filter. You never know when
something too big to be ingested will get sucked in.
Tony
Old July 13th 09, 10:33 PM posted to rec.aviation.homebuilt
Peter Dohm
"Scott" wrote in message
Bob wrote:
To All:
Annd if
-R.S.Hoover
overhaul) is the addition of an air inlet on the engine baffle between the
nosebowl and the cylinder (pilot side) with tubing running from it to the
heat muff. My old system just had the inlet pipe of the Aeronca heat muff
unconnected to anything and I noticed that the aluminum heat muff looked
like it had melted a bit where it was contacting the exhaust pipe so I
added the cool air inlet to help cool the heat muff a bit. Maybe it cools
it too much and I'm just not getting enough heat, so increasing the
surface area sounds like a good idea...just unsure of the method. I know
I DO NOT want FOD running into the carb as that is SURE to cause the
Scott
Aha!
I read your post this morning and didn't think much about it at the time;
but but it now occurs to me that the cooling air gains a lot of heat passing
through the cooling fins of the engine--so that you may have created your
own problem by sending cold outside air directly into the heat muff.
Just a thought.
Peter
Old July 14th 09, 12:40 AM posted to rec.aviation.homebuilt
On Jul 13, 3:33 pm, "Peter Dohm" wrote:
Aha!
Just a thought.
Peter
And since those Aeronca muffs tend to leak a lot, forcing air into
them might cool the pipe too much just when the heat is needed. The OP
needs to seal up those muffs. The connection to the baffling needs to
stay, since a muffed pipe with no airflow (except when carb heat is
on) will overheat and burn out. Piper had plenty of that sort of
trouble on their Cherokees.
The OP gets a 50 RPM drop in cruise, with carb heat. That ain't
much.
Dan
Old July 14th 09, 04:31 AM posted to rec.aviation.homebuilt
On Jul 13, 9:09 pm, Scott wrote:
Actually, my muffs fit fairly "airtight" around the exhaust pipes. I
actually had to cut and trim a bit to make them fit at all, so I think
the majority of the heat produced is captured inside the muff. However,
I just don't think the two halves of aluminum have enough thermal mass
to provide a ton of heat to the carb, so I think I still need to come up
with a safe way to add mass inside the muff.
Scott
The Aeronca muff often involved a deflector plate, attached to a small
strut across the pipe vee, that prevented the air from travelling
straight across the chamber from the inlet to the outlet. The
deflector made the air flow around the pipes to get from one side to
the other. Lots more heat. Does your have that?
Dan
Old July 14th 09, 04:42 AM posted to rec.aviation.homebuilt
Morgans[_7_]
How about a diverter shaped to make the air corkscrew around the pipe?
Jim in NC
Old July 14th 09, 08:25 AM posted to rec.aviation.homebuilt
jan olieslagers[_2_]
cavelamb schreef:
See Tony Bingles books...
Confusing dear old Tony with dearer older Capt. James Bigglesworth?
Old July 14th 09, 08:55 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
Never heard of him!
Infamous engine stall on takeoff James Robinson Piloting 8 January 4th 07 05:08 PM
Continental engine E185 Philippe Home Built 4 July 14th 04 01:14 PM
Continental Tierra 285 Engine chip Aviation Marketplace 5 May 8th 04 01:02 PM
Continental Tierra 285 Engine chip Home Built 4 April 30th 04 02:12 AM
Continental A65 engine Philippe Vessaire Home Built 0 July 10th 03 05:49 PM
