Magnetic shielding
Old July 20th 09, 03:29 PM posted to rec.aviation.soaring
[email protected][_2_]
Default Magnetic shielding
On Jul 20, 6:51*am, Steve Freeman wrote:
I am worried about interference because no matter what direction I am
flying, the compass only points to within about 15 degrees of south.
Not much use in an emergency. I do carry a GPS PDA and have an LNAV/
GPSNAV in the panel but would like to have an operational compass.
Also not sure if FAA item or not but would guess that it is.
Understood, I have one too - for FAA (sigh) and nostalgic reasons.
Sounds like something is seriously magnetized in your instrument panel
- do you have a big radio or vario speaker nearby? And have you been
able to place the compass anywhere in your cockpit and get correct
readings? It could be a bad compass...I've seen whiskey compasses
stuck in all sorts of improbable places and work OK!
Kirk
66
Old July 20th 09, 06:25 PM posted to rec.aviation.soaring
Brian Whatcott
On Jul 19, 9:19 pm, "
On Jul 19, 6:41 pm, Steve Freeman wrote:
I need to mount a compass on the instrument panel glare shield. There
is magnetic interference in most all of the areas that are best for
viewing the compass. Anyone know anything about the various forms of
magnetic shielding available now. On one site alone they sell over 5
different types of material. A compass manufacturer once recommended
this as an easy solution to interference in a power plane but it was a
few years ago and I do not remember the material we used.
Not trying to be a smart ass, but why are you worried about mag
interference? I mount my little PZL mag compass right next to my
electric varios, PDA power supplies, GPS antennas and when I swung the
compass, the error was within my need to hold a heading in a glider...
This may be considered heresy, but with GPS, the old magnetic compass
should be relegated to emergency status, at best - better (and
considerable less expensive, to boot) to carry a cheap handheld GPS in
the cockpit, along with some spare batteries.
Unless this is an EASA (or FAA) thing, of course...
Just curious.
Cheers,
Kirk
66
I just have to ask: have you swung the airframe with all power switched
off? You could be seeing the effects of some magnetized metal.
Brian W
Old July 20th 09, 06:30 PM posted to rec.aviation.soaring
Wayne Aspland
At 14:22 20 July 2009, Steve Koerner wrote:
And Leroy, where are you suggesting that Mr Freeman put this mu-
metal? If you put it anywhere near the compass you will significantly
alter the compass readings. If it happens that he has a speaker on
his panel (or an instrument that has a speaker built-in) then it is
concievable that encompassing the speaker in mu-metal could be helpful
but that is the only scenario I could see for mu-metal. If he does
have a loudspeaker on the panel, a better solution would be to remote
it.
Brian W is correct that if he happens to have power wiring running
near the compass, then get it away from the compass and twist it with
the return.
Alas, why bother? Compasses are relics with all sorts of annoying
foibles.
Steve
Most pure gliders don't require a compass under EASA, (look in the
equipment list in the type certificate) If you feel you need one just in
case all the GPS kit gives up at the same time, buy one from halfords,
keep it it the pocket and stick it on the canopy when required, well away
from all those nasty (none working) sources of magnetism. More than good
enough to get you home.
Old July 20th 09, 06:31 PM posted to rec.aviation.soaring
Brian Whatcott
it.
the return.
foibles.
Steve
For powered aircraft in particular (including all civil aircraft) a
magnetic compass is mandatory equipment.
Brian W
Magnetic attraction Jim Beckman Soaring 0 June 29th 07 02:29 PM
Why are headings still magnetic? Mxsmanic Piloting 87 September 11th 06 05:34 PM
Magnetic reversal Everett M. Greene Instrument Flight Rules 12 April 9th 05 09:40 AM
Do you use your magnetic compass? Roger Long Piloting 42 May 25th 04 12:08 PM
DIY ignition shielding? Michael Horowitz Home Built 3 September 11th 03 04:28 AM
