Sub-Launched SAMs
Old September 18th 09, 05:35 PM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
Alan Lothian
Default Sub-Launched SAMs
On Sep 18, 4:15*pm, (Derek Lyons) wrote:
Everybody keeps adressing the situation where the ASW asset 'only has
a sniff'. *Yeah, it's madness to launch then and give yourself way...
But that ignores the rest of the situation - like when they have more
than a sniff and are actively attempting localization.
Fair point. I'm happy to sit back and read posts from people who know
more than I do.
And isn't it a joy when the group does what it's supposed to do?
  #42
Old September 18th 09, 08:52 PM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
BlackBeard
On Sep 18, 12:04*pm, Juergen Nieveler
Alan Dicey wrote:
Part of the problem is giving away your position. *How about deploying
the SAM in a specially designed torpedo, so that it swims away from
you a significant distance before surfacing and letting fly?
Formidable problems of targetting the SAM, of course, and you've still
told the world that there is a hostile sub in the vicinity.
As I understand it, Polyphem at least IS launched via the torpedo tube,
and aimed by FO line...
Juergen Nieveler
"Hello", lied the politician
When all the problems with detection and targeting are all talked our
here then we can move into missile flight dynamics-- and why when the
ASW platform is close (as is being suggested) it is so much harder to
hit.
BB
  #43
Old September 18th 09, 10:15 PM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
Paul J. Adam[_3_]
In message
David E. Powell writes
Such as lightweight torpedoes on destroyers and frigates, where the
ship would already be in rane for a Submarine with heavyweight
torpedoes?
Detection ranges can be unpredictable; the submarine may be trying to
sneak past the escort to get a shot at the HVU it's protecting; and, if
the escort's attacked or it detects a submarine torpedo firing, an
immediate countershot may discompose the submarine, which will reduce
the effectiveness of a wire-guided torpedo (a lively torpedo
countermeasure manoeuvre is likely to break the guidance wire, so when
the torpedo goes for the "ooh, shiny!" acoustic decoy it can't be nudged
back onto the real target).
Again, the DD/FF is an obstacle in the submarine's path, rather than a
primary target: since it's likely to be carrying lightweight torpedoes
in its air weapons store, why not give it the option to launch them? (On
a Type 23 they're fired straight from the magazine: the torpedo room has
two tubes either beam plus a door to the hangar)
He thinks too much, such men are dangerous.
Paul J. Adam
  #44
Old September 19th 09, 05:22 AM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
David E. Powell
On Sep 18, 5:15*pm, "Paul J. Adam"
In message
torpedoes?
True. I should have considered modern carrier groups or convoys could
spread out over quite a bit of distance. If the sub fires at a
destroyer or frigate, they maybe targeting themselves and losing the
chance at the main target.
That's a good argument too. It reminds me of a book I read about the
PQ 17 convoy of WW2, where the crew of a freighter cut off from a
dispersed convoy, having been warned not to tamper with the cargo,
broke out all manner of weaponry anyway because they figured they had
it anyway and were on their own, so why let it just sit? I recall they
used machine guns mounted on tanks, along with some other weapons, to
deefnd against air attacks.
Paul J. Adam
  #45
Old September 19th 09, 05:38 AM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
BlackBeard
On Sep 18, 9:22*pm, "David E. Powell"
In message
torpedoes?
Sheesh... Boomer sailor right?
(relax David, it was all in love- fellow Dolphin wearer...)
BB
  #46
Old September 19th 09, 06:17 AM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
David E. Powell
In message
torpedoes?
Sheesh... Boomer sailor right? *
BB
Sir, you have given me a great honor, but I have never been a
submariner. I tip my hat to you guys.
David
  #47
Old September 19th 09, 07:27 AM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
BlackBeard
On Sep 18, 10:17*pm, "David E. Powell"
In message
torpedoes?
BB
David
Sheesh... I think I made this mistake before. I'll blame the
meds* I took before I posted this time
I'm just going to have to start another thread and generate a list
of the bubbleheads posting here. I know Derek, Vaughn, and Max all
claim the fish. Just can't keep the rest in memory.
Actually have met and drank with Max with his port and starboard
fish- in a historic Submariners bar, at a book signing for a Submarine
book, sitting across from the ****ter off the USS Dolphin as an
authentic klaxon sounded and required us to drink nuclear depth
charges.
My apologies for including you among the unwashed Denizens of the
Deep... I respect you, your posts, and demeanor. However you should
not be accused of having participated in the terribly painful,
demeaning, degrading, raw sexual process that is required to be called
a Submariner...
BB
  #48
Old September 19th 09, 08:10 PM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
Alan Dicey
Juergen Nieveler wrote:
Alan Dicey wrote:
Part of the problem is giving away your position. How about deploying
Reading up on Polyphem, it appears to be a 60kM range cruise missile,
land attack or anti-ship. Mind-bogglingly, it is fibre-optic guided
right onto the target, so takes off with 60kM of fibre on a bobbin.
Doesn't meet the requirement I had in mind, which was to separate the
apparent source of the missile from the submarine's actual location.
Mind you, if you could develop a sufficiently intelligent SAM that could
target overflying hostiles on its own, you could lay an anti-aircraft
minefield, and be miles away when the missile launched. Pretty vital to
have included foolproof IFF, though.
  #49
Old September 19th 09, 08:45 PM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
vaughn[_2_]
"BlackBeard" wrote in message
claim the fish.
start flashback
Got them fair and square too. Caught them in my teeth in a bar in Dunoon
Scotland, where they had been dropped into a beer mug full of assorted
shots. Heaving one's guts out afterwards was considered part of the game.
When I came out of the pub's smelly head, I was still wearing that nasty
toilet seat. My shipmates called me "horsecollar" from that day on.
The next day, the XO reclaimed them so that a visiting assistant SecDef (the
Mr. Packard from HP) would have a ceremony to perform. The SOB was late, so
I had to shiver on deck for an hour while I waited to get my dolphins back.
end flashback
Vaughn
  #50
Old September 20th 09, 03:33 AM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
Derek Lyons
fish
If your work ever brings you up this way, we'll have to hit the local
brewpub... (Ralph L, occasional poster here in SMN, also lives in the
vicinity.)
Can't quite put it away with the same enthusiasm/volume as I did in
the old days though.
D.
Touch-twice life. Eat. Drink. Laugh.
http://derekl1963.livejournal.com/
-Resolved: To be more temperate in my postings.
Oct 5th, 2004 JDL
one of uncle sams aircraft? John A. Weeks III General Aviation 1 September 12th 06 09:18 PM
one of uncle sams aircraft? Eeyore General Aviation 1 September 10th 06 04:19 AM
one of uncle sams aircraft? Stubby General Aviation 0 September 9th 06 11:11 PM
Good prices on Aeroshell oils at Sams club Fastglasair Home Built 4 October 2nd 04 11:30 PM
Will LPI radar be used to guide SAMs? Chad Irby Military Aviation 6 January 4th 04 09:02 PM
