Retrieve Contact - Radio Relay?
Old September 21st 09, 03:16 AM posted to rec.aviation.soaring
Chris Ruf
Default Retrieve Contact - Radio Relay?
Flying out of Marfa Texas, about 5 years ago a couple of us landed out
- and I do mean out. I had to hike a few miles past several jack
rabbits, and many spiders and snakes to the only ranch house on
200,000 acres.
We were having little luck with cell phones so I tried to get an
airliner to relay. I called on 121.5 multiple times. We were just in
such a remote area I got no response.
Luckily we did not have an emergency because we had no luck with the
airliner relay.
I'd try the scan function on my handheld radio next time as that is a
good suggestion.
How else would you know what frequency to try to call on?
I figured that a 5w handheld radio would have a pretty good range to
reach airliners at cruising height.
Chris
Old September 21st 09, 03:28 AM posted to rec.aviation.soaring
jcarlyle
I don't know about that. My club uses handhelds for the field crew,
and at 4,000 to 5,000 feet 2 to 3 miles away from the field you cannot
hear the field radios at all (although they can easily hear a glider
radio from that distance and height).
-John
Old September 21st 09, 03:31 AM posted to rec.aviation.soaring
Mike Bamberg
- and I do mean out. *I had to hike a few miles past several jack
200,000 acres.
airliner to relay. *I called on 121.5 multiple times. *We were just in
*Luckily we did not have an emergency because we had no luck with the
airliner relay.
good suggestion.
Chris
I teach power-plane instruction as well as glider and teach my
students to monitor 121.5 if they can, while remaining on the assigned
frequency. I've also heard a number of airlines contacted by ATC and
asked to monitor 121.5 and they almost always reply that it is their
standard procedure.
The chances of someone listening to 121.5 is pretty good but as noted
above, not guarenteed.
Mike
1946 stinson ( Radio Buss Relay Install ) goldaussy Piloting 1 May 20th 09 06:49 PM
Using radio to contact persons on ground while flying? steve Piloting 27 July 28th 06 03:18 PM
Relay David Home Built 5 July 20th 04 04:11 PM
Contact cleaning on older Nav radio Mike Noel Owning 4 September 15th 03 02:28 PM
Electrical Relay Help Jeff Home Built 10 August 29th 03 04:03 AM
