TRIG TT21 Transponders
Old September 22nd 09, 10:23 PM posted to rec.aviation.soaring
Tim Mara[_2_]
Default TRIG TT21 Transponders
The new TSO'd TRIG Mode S transponders have been shipped from our US
Distruibutor and will be here by the end of the week...and they do in fact
have the US TSO approval as I mentioned earlier
see http://www.wingsandwheels.com/page4.htm for details
thanks
tim
Old September 22nd 09, 11:58 PM posted to rec.aviation.soaring
Paul Remde
Hi,
I also will have them in stock in a few days. I also will have wiring
harnesses in stock for connecting the transponder unit to the display/user
interface unit.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Tim Mara" wrote in message
thanks
tim
Old September 23rd 09, 04:19 AM posted to rec.aviation.soaring
Larry[_5_]
So I've got a mode-C xponder in my current glider. Since I fly near
Reno airspace, when I get another glider I'll be installing a xponder
if it doesn't already have one.
Question- is there a reason why I would want a mode-S rather than a
mode-C?
Thanks,
Larry
Old September 23rd 09, 05:47 AM posted to rec.aviation.soaring
Darryl Ramm
On Sep 22, 8:19*pm, Larry wrote:
So I've got a mode-C xponder in my current glider. *Since I fly near
mode-C?
Thanks,
Larry
Not really, in Europe Mode S is important. In the USA not so. Until
the TT21 my advice would have been to just by the cheaper Mode C like
the Becker 175W.
With Mode S you get a permanent aircraft ID so ATC can always tell who
you are. Some folks might not like that compared to Mode C. The Trig
will allow ADS-B data-out tricks in future but that is about a decade
from needing this. The main thing with the Trig TT21 is that it is
easier to install, smaller, more power efficient and around the same
price as competing Mode C transponders and it is Mode S with "extended
squitter" support aka 1090ES/ADS-B data out for future possible use.
As I've said before the TT21 is a game changer and if it performs as
good in practice as it looks on paper it will do well. I currently fly
with a Becker Mode-C 175W (my second in two gliders I've owned). If I
was buying a new transponder today it would be the TT-21.
Darryl
Old September 23rd 09, 04:58 PM posted to rec.aviation.soaring
Richard[_9_]
mode-C?
Thanks,
Larry
the Becker 175W.
from needing this. *The main thing with the Trig TT21 is that it is
Darryl
Darryl,
I agree that the Trig appears to be a nice transpoder and reasonably
priced.
It does not appear to be any easier to install than a Becker or
Microair or have any better specs that the Microair or Becker in a
Mode C environment.
Trig 11min – 33 max Volts DC. Typical 5 Watts @ 14Volts.
Is the 11v acceptable in a Glider?
Becker 9.5 V to 32.2 V DC
Microair 10v to 33 v .15 to .200 amps
Trig 11 to 33 V .150 to .280 amps (from installation manual)
Low Power Design
The TT21 has one of the lowest power consumptions for any transponder.
With typical power consumption of around 5 watts, it can operate from
battery power for gliders or balloons for long duration flights. In
powered aircraft you can be sure that the TT21 is not making heavy
demands on your electrical system.
5 watts at 12 v = .41 amps
5 watts at 14v = .35 amps
Where did the .280 amps come from? I think all the manufactures play
with specifications.
An issue may be the temperature or the glider cockpit. The Trig
installation manual states The TT21 is certified to operate
correctly down to -20°C, but at low temperatures the display may be
impaired. On a cold day you may need to wait for the cockpit to warm
up to ensure normal operation.
All warranties are F.O.B.
Trig Avionics Limited Heriot Watt Research Park Riccarton, Currie,
EH14 4AP
Trig Avionics will not accept or pay for any charges for warranty work
performed outside our factory without prior written consent.
I perfer not to be a beta tester for a new instrument in the US
airspace environment. TSO only means they have completed the paperwork
requirements. I have experience the early problems with both Becker
and Microair. (They are now both reliable in the US airspace
environment)
Richard
www.craggyaero.com
Old September 23rd 09, 07:34 PM posted to rec.aviation.soaring
Darryl Ramm
Richard
[snip]
Darryl,
priced.
Mode C environment.
The Trig unit with its two relatively small display/RF units appears
to me to be easier to install in many situations such as with with
tight panel (and behind panel) space and RF cable routing problems
(install the RF box at the antenna). I'm a bit lost as to why you
don't think the Trig has an "easier to install" benefit.
Trig 11min *– 33 max *Volts DC. Typical 5 Watts @ 14Volts.
Is the 11v *acceptable in a Glider?
Apparently yes. These are nominal input voltages. With modern switch
mode power supply technology I'm not so worried about the nominal
lower voltage range. This would be something to check with Trig (I'll
send off an email when I get time). I've not seen any problems
reported by the early users of the Trig TT21 and I would have expected
to from the folks I've been in contact with. Anybody out there had low
voltage issues with the TT21?
Microair 10v to 33 v * *.15 to .200 amps
Trig *11 to 33 V * .150 to .280 amps (from installation manual)
Low Power Design
5 watts at 12 v = *.41 amps
Where did the .280 amps come from? *I think all the manufactures play
The power requirement comes from the Trig product specs in their
brochure and in their installation manual. Trig states the power
consumption of their TT21 is Idle: 0.15 A Active: 0.28 A, both at 14V.
Remember this includes the internal encoder, the encoder power
consumption for other transponders should be included in any
comparison.
You are trying to compare a very rough "about 5 watts" statement from
the same exact product data sheet as the more detailed specs. When
somebody says "about 5 bananas" Do you assume they have exactly 5.0
bananas, between 4 and 6 bananas, between 1 and 10 bananas? You are
trying to reverse out the typical amperage from the "about 5 watts"
and then slamming them that all this stuff "is played with". They
provide detailed current specs, so be fair and use those.
Transponder power specs are complicated because they depend on
interrogation rate (SSR, TCAS and other) and on the encoder power
consumption that can be fairly temperature dependent (is that Encoder
in a drafty location?). My experience with measuring actual Becker
transponder power consumption is that the specs they provide are very
reasonable. I have not measured other transponders in actual use.
Trig do appear to use a fairly modern, low power encoder. I'd love to
get my hands on a TT21 to do actual power consumption tests. But I
have no reason to believe that the Trig would not be as low a power
consumption as they claim. A very nice thing for sailplane use.
An issue may be the temperature or the glider cockpit. *The Trig
installation manual states * The TT21 is certified to operate
This is a compete red herring. The LCD displays used on all competing
products will not operate at low temperatures. This is a fundamental
"feature" of LCD display technology. For example the Becker
transponders also spec a minimum operating temperate of -20C. It is
quite likely the LCD display performance sets this lower limit. Kudos
for Trig for clearly explaining this low temperature limit in their
documentation.
EH14 4AP
Are you just cut and pasting stuff of the Trig web site or did you
check with their USA distributor?
Southeast Aerospace is the USA distributor. They have publically
stated (see video interview at http://www.youtube.com/watch?v=TAvyjaYzq04)
that during the three year warranty period that warranty repairs are
being handled by field swap of units. With new technolgoy products I
actually think an initial approach of all facory repairs is the right
one. A good warranty period and a distubutor who is stocking spare
units and willing to field swap is a *great* approach. And given what
I think SEAs repair capabilities are it could be that they will do
actual repair in the field in future, I'm not sure. A three year
warranty period is great on new products, I believe both Becker and
Microair transponders have two year warranty period (but the encoder
may have a shorter warranty period - e.g. I believe the ACK A-30 has a
one year warranty, with the Trig TT21 the warranty covers the encoder
as well). Maybe Paul can update his transponder comparison table with
warranty period information.
environment)
Richardwww.craggyaero.com
I've also personally had very good experience with Becker USA service
and would highly recommend Becker because of this. Luckily I never had
any early teething problems with Becker products--the repairs I've
needed were for external damage to a transponder. I had enough bed
experiences with early Microair radios that I never want a Microair
anything in my glider ever. But I do hear that their transponders work
well, and I do occasionally use one in a rental glider. I prefer the
Becker UI however. And I see they went through some problems with
them ultimately requiring airworthiness bulletins. And I believe they
did sorted out their radio problems. The teething and support problems
that Microair had on their VHF radios is absolutely the sort of issues
I would be worried about with adopting *any* new products. So Trig and
SEA has to prove they are up to this. Trig have been shipping the TT31
for several years, mostly in Europe so I'd hope any gross vendor
problems would be visible by now. They also have a good distributor
with SEA in the USA. So purchasers need to make their own decisions,
and the best the rest of us can do is watch reports from early
adopters.
I have no interest in any of these products, resellers etc. My
interest is only in encouraging transponder adoption in areas like
around Reno and other areas of mixed commercial/fast Jet and glider
traffic. I did help Paul Remde with information for the transponder
comparison table on his website at
http://www.cumulus-soaring.com/trans...mparison_Table
to try to explain the different transponder capabilities.
Darryl
Trig TT21 Transponder receives FAA TSO approval Paul Remde Soaring 12 September 19th 09 02:47 PM
Trig TT21 in Experimental Aircraft Paul Remde Soaring 5 July 5th 09 03:15 AM
Trig TT21 Transponder Thoughts? jcarlyle Soaring 16 June 23rd 09 04:38 PM
transponders in EU Sandro Soaring 2 February 2nd 07 01:02 PM
forgotten trig for climb angle... xerj Piloting 5 January 29th 07 01:08 PM
