Retrieve Contact - Radio Relay?
Old September 23rd 09, 03:10 PM posted to rec.aviation.soaring
V1
Default Retrieve Contact - Radio Relay?
Thanks to everyone who took the time to reply to this thread. I saw a
lot of useful tips - especially about what frequencies to try, and
practical experience that says this is a feasible option in the
(hopefully rare) cases where the normally planned communication paths
fail.
- Frank
Old September 23rd 09, 07:15 PM posted to rec.aviation.soaring
Nyal Williams[_2_]
Frankly (gri n), I'm not up on this at the moment, but there used to be a
frequency set aside for air-to-air communications. If such still exists
that would be the discret frequency to use. Did that frequency get caught
up in the re-distribution of frequencies years ago?
fail.
- Frank
Old September 23rd 09, 08:27 PM posted to rec.aviation.soaring
Mike Bamberg
frequency set aside for air-to-air communications. *If such still exists
that would be the discret frequency to use. *Did that frequency get caught
fail.
- Frank- Hide quoted text -
- Show quoted text -
The "standard" air-to-air is 122.75 below 18,000 ft and 123.45 above
18,000 ft.
MIke
Old September 23rd 09, 09:18 PM posted to rec.aviation.soaring
R[_2_]
18,000 ft.
MIke
Contrary to the rest of ICAO, In the US 123.45 MHZ is not an Air to Air
frequency. 123.45 MHZ is designated for non-governmental flight
testing. However, a special use authorization is allowed as acceptable;
air to air, for aircraft in remote locations to use it to exchange
operational information and facilitate the resolution of operational
problems. No altitudes are specified.
Russ
Old September 24th 09, 08:01 PM posted to rec.aviation.soaring
Eric Greenwell
Frank Whiteley wrote:
On Sep 22, 9:16 am, Frank Whiteley wrote:
On Sep 21, 3:35 pm, bgrly wrote:
On Sep 21, 3:15 pm, Bela wrote:
On Sep 20, 6:57 pm, CindyB wrote:
On Sep 20, 11:46 am, sisu1a wrote:
Does anyone have any real-life experience using this method? Or any
input on how the FAA (in the US) might view this strategy?
- Frank
Pre-celly, this used to be common practice, and I suspect commonly
I'm not sure on the FAA's take on it,
but I imagine that it falls into the realm of legal usage of the freq.
The FCC however may feel otherwise if you aren't current on your
license to operate a 2 way
-Paul
This is a very valid techinique.
It is not to be used in place of normal comm procedures,
or to substitute for poor planning, but I have been party to using it
in several situations.
Local pilot wanders off on first Spring X-C, with no ship batteries,
poor handheld batteries, and more enthusiasm than sense.
When the day overbuilds and cuts him off from home, he outlands.
He calls in the blind on the 'approach' frequency, and gets an
enroute G.A. pilot to switch to the home airport CTAF and relay a
message. The airplane pilot handled his changes off/on to the
ATC frequency. Very considerate airplane guy, and happy to involve
himself. Knowing the enroute local ATC frfequency was about the
best part of the day's execution by that glider pilot.
Tonopah Nationals .... big CBs end the day, folks scattered all
over creation. Contest Air goes up to relay line-of-sight for crews
and
pilots seeking each other. Poor radio quality due to the HEAVY
rain showers and interior glider cockpit noise on the ground,
and lightning in many quadrants. Contest Air goes home. One
crew was enterprising enough to use scan function on their handy-
talkie and ask the airliner to switch for an 'urgent' relay. The
airliner
reached the pilot, now not in heavy rain on the ground, and got
his position and handed data to crew.
Remember to WAIT for the relay time and the other party out of
range to answer to the relaying airborn machine, rather than
stepping on transmissions. . .
Region 12 contest at Inyokern, 1999? Beloved silly Fred Ebner had
not been heard from and it was long after dark. We had launched
Contest Air for relays, sent Air on course line ( love those AST's
for finding folks late in the evenings), still never raised the pilot.
Phoned ATC to ask for the assistance on both possible
frequencies, and handled listening and thank yous from the
contest HQ ground. Three airplanes tried to help that
night. Turns out, Fred was hiking from the wrong side of the
Owens River, with no hand held, to cross the water and reach the
highway. He was tired, dry, cranky, and not in the mood to be
reprimanded for not either 1)staying with the glider, or 2) having
a ground communication method during the walk or 3) relaying
out from the glider prior to walking. We were certain to thank
ATC for their help with a follow up phone call when we found Fred.
Landouts can be serious for pilot health and safety in the
'boonies'. Communications can be important to prevent
unneccesary search or worries. If the radio work is handled
fairly professionally, with good cause, no one (FAA/FCC)
will make a fuss.
Cindy Bwww.caracolesoaring.com
A few years ago I shared a chair lift with an FAA big-wig and asked
the same.
Response was: a very valid method, provided you make intent clear,
i.e.: asking for relay, not an emergency.
I would also try Aircraft Corp. frequencies first, that are monitored.
Here is a good source:http://ku4ay.net/scanner/airemergency.html
Bela
Other than 121.5, a good frequency would be the ATC sector frequency
for that area. These are shown on the IFR enroute charts and listed in
the DOD IFR supplement and probably in the Airport/Facility Directory.
This is what you would find with a scanning hand held radio, as some
are quite busy.
bgrly
I carried these when I flew regularly out of Truckee. Got a retrieve
assist after landing out by calling on an overhead frequency then
moving to a discrete frequency.
Now there's something I was wondering about. How would you know which
discrete freq to use? Would 123.5 be appropriate, or is there a better one?
Ed
Long time ago, IIRC we moved to the Truckee base for the relay.
Frank
I'll add that it facilitated communications as I could hear half of
the conversation as could Tahoe-Truckee Soaring. If the IFR enroute
frequency had failed, I was quite prepared to call on 121.5 to
establish comms initially. I landed at a small strip with a barn/
hangar and house, but no one around and a non-working phone at the
hangar. Had to wait until day operations ended. No one arrived
before the evening tow home.
Frank
Is it really useful to drag along the entire thread, now over 150 lines
long? Maybe I have a low pain threshold, but somewhere around 100 lines
of old message and only a two three new lines, I skip to a message
that's much smaller.
* "Transponders in Sailplanes" http://tinyurl.com/y739x4
* Sections on Mode S, TPAS, ADS-B, Flarm, more
1946 stinson ( Radio Buss Relay Install ) goldaussy Piloting 1 May 20th 09 06:49 PM
Using radio to contact persons on ground while flying? steve Piloting 27 July 28th 06 03:18 PM
Relay David Home Built 5 July 20th 04 04:11 PM
Contact cleaning on older Nav radio Mike Noel Owning 4 September 15th 03 02:28 PM
Electrical Relay Help Jeff Home Built 10 August 29th 03 04:03 AM
