On Tue, 6 Oct 2009 21:51:00 -0700, "Bill Noble"
wrote: I originally posted this in the metal working newsgroup, some folks there thought the part might be recobnized by somone here - so, it's worth a try - any clues? thanks: I think this is probably quite old, but so far I have no idea what it is (or was part of) - there is another like it that has been sharpened to use as a boring bar - clearly that was not its original purpose. the one pictured in the drop box appears to be original - but orignal what, is the question. here are the links to the drop box: http://metalworking.com/Dropbox/P-W-1.JPG http://metalworking.com/Dropbox/P-W-2.JPG http://metalworking.com/Dropbox/P-W-1.txt Anyone got any clues about this item? The text file from the drop box is reproduced below: Mystery Pratt & Whitney tool - the cylindrical shank is exactly .500 inches, it says on the shank, the following: NO. 32 HS.-36 E-12 P&W MFD CT Made in USA it is NOT a drill bit. The part that extends beyond the 1/2 inch diameter shows a wear line like it was riding in a keyway. The point seems to be lathe turned, the 1/2 inch shank appears to be ground Bill - www.wbnoble.com first guess was a spot facing borer but the wearline contraindicates that. maybe a machinable dead centre for some special tooling jig. |
Strange 747/Pratt & Whitney project | Ricky | Piloting | 14 | February 1st 09 11:24 PM |
PRATT & WHITNEY PROPOSES F-22A ENGINE VARIANT FOR LONG-RANGE STRIKE | Mike[_7_] | Naval Aviation | 0 | May 30th 07 02:44 PM |
Was the Pratt & Whitney Double Wasp the best engine of WW II? | Dave Kearton | Aviation Photos | 18 | January 12th 07 07:20 PM |
Question Pratt & Whitney Tool ... | joseph | Restoration | 0 | October 1st 05 02:57 PM |
World War Two Era U.S. Radial Engines (Curtiss and Pratt&Whitney) | Lincoln Brown | Military Aviation | 10 | February 13th 04 04:30 AM |
