Help estimating altitude without altimeter?
Old October 28th 09, 03:07 AM posted to rec.aviation.soaring
ZZ
Default Help estimating altitude without altimeter?
Tom:
How many patterns have you flown since you began your training? Until
you develop a clear picture in your mind of how your airfield looks at
different points in the pattern, you are experimenting and this will
work eventually. I have found a way to accelerate this process a bit. I
have my students fly their patterns at precise altitudes at specific
points in the pattern. And I insist on precise airpeed control as well..
This accomplishes two things..precise pattern flying...the same picture
every time and this "groove becomes epoxied into their brain more
quickly. Then, when I take their altimeter away and change runways, they
have no problems repeating the maneuver properly. Now I am all too
familiar with the argument against this technique i.e. what are they
going to do if they are landing at a field without the familiar
landmarks? It's that profile to the runway that they are really learning
by repeating the same profile time after time.
tstock wrote:
Hi, as a beginner I am still a little rough at this. I've done 3
successful patterns with no altimeter, but today I failed one
miserably with my instructor. There were two issues which threw me
off. 1) we towed higher than the past attempts, and 2) instead of
entering the pattern at a familiar entry point, he had me circle
directly over the airport which made judging the angle a bit
difficult.
While we did eventually land safely, I failed miserably at setting up
the first pattern (way too high) and was forced to land on the
opposite runway (which left me way too low). A little scary but a
good learning experience... one I do not care to repeat anytime soon.
I know I should be looking for the landing strip to be about 30
degrees below the horizon. But how can I do this when circling
directly over the field looking down at it?
I made a second attempt and moved my circle so that the outermost edge
of the circle was where I would enter the downwind.. I succeeded this
time. Unfortunately we also only towed to 1500' AGL which left me
with a much smaller chance of messing things up... so I can't say I am
completely confident despite the success.
Are there any easy methods for estimating the angle from the horizon?
For example a fist at arms length is 10 degrees, but obviously I can't
hold my first at arms length through the canopy. The method I've
used is to wait until my aim point aligns with the outer most edge of
the air brakes. To measure 45 degrees I look directly over the top of
my shoulder... is there a better method?
Thanks
-tom
Old October 28th 09, 03:21 AM posted to rec.aviation.soaring
ZZ
ZZ wrote:
Tom:
Tom
I mashed on the Send Button prematurely.
So to wrap this up, fly your patterns as precisely as possible, as you
progress, learn to detect smaller and smaller errors and correct them
early. Fly the same groove to the runway every time and you will soon be
comfortable landing almost anywhere without no stinking altimeter.
Paul
ZZ
difficult.
Thanks
-tom
Old October 28th 09, 08:25 AM posted to rec.aviation.soaring
Surfer!
In message , ZZ
writes
Tom:
Snip
I would say it's 'how the reference point looks'. We can have a
reference point anywhere, but if landing out we won't be seeing our own
familiar airfield. Is the reference point technique taught in the US?
Surfer!
Email to: ramwater at uk2 dot net
Old October 28th 09, 05:08 PM posted to rec.aviation.soaring
bildan
On Oct 28, 2:25*am, Surfer! wrote:
In message , ZZ
writesTom:
Snip
I would say it's 'how the reference point looks'. *We can have a
familiar airfield. *Is the reference point technique taught in the US?
Surfer!
The best 'reference point' is the intended landing surface. Anything
else is likely to be misleading. Even telephone poles are not all the
same height or spacing.
There are lots of clues to height which taken together can give a
pretty accurate estimate. Pilots may not even be aware of all the
clues they're using, just that with increasing experience, their
estimates begin to work.
One old skydiver clue is that when people stop looking like ants and
start looking like people, it's time to pull. That's about 2000' AGL
and not a bad height to be over the landing area looking for wind and
obstacles.
Old October 28th 09, 06:04 PM posted to rec.aviation.soaring
nate_fl
In message , ZZ
writesTom:
Snip
Surfer!
The best 'reference point' is the intended landing surface. *Anything
else is likely to be misleading. *Even telephone poles are not all the
pretty accurate estimate. *Pilots may not even be aware of all the
start looking like people, it's time to pull. *That's about 2000' AGL
obstacles.
Anyone try using the wing vs. runway relationship? In the Skyhawk I
was taught to keep the runway 1/2 to 2/3 up the strut, correcting for
wind. I know that this would lead to flying an ever closer pattern as
you descend, but could it not be used to get you in the groove up to
abeam the touchdown point? Then it would be a matter of TLAR from
there to touchdown.
I offer this as a question, not a suggestion. I've done very little
flying away from the home field, and I live in a very flat state.
Old October 30th 09, 02:54 PM posted to rec.aviation.soaring
tstock
there to touchdown.
This is sort of how I ultimately did it... when my aimpoint was at 9
o'clock, it appeared about 1/3 of the way down from the wing tip, just
under the air brake. This was about 800'.
-tom
Old October 29th 09, 02:52 AM posted to rec.aviation.soaring
ZZ
The reference "point" assuming that you can see it, is the the runway or
more specifically, the TDZ.
Paul
ZZ
Surfer! wrote:
In message , ZZ
writes
Tom:
Snip
Old October 29th 09, 09:08 AM posted to rec.aviation.soaring
delboy
If you can only see whole woods or forests you are quite high. If you
can see individual trees you are getting a bit low. If you can see the
branches you are very low, If you can see the leaves...don't even
ask!
If you can see your reference point, estimate your distance away from
it and judge the angle (should be about 15 degrees), you should be
able to land accurately with a bit of practice, without reference to
the altimeter. Remember that the altimeter is pretty useless when
outlanding at a field of unknown elevation.
Derek Copeland (UK gliding instructor)
Paul
ZZ
Surfer! wrote:
In message , ZZ
writes
Tom:
Snip
familiar airfield. *Is the reference point technique taught in the US?- Hide quoted text -
- Show quoted text -
Old October 29th 09, 02:48 PM posted to rec.aviation.soaring
ZZ
I knew that my original comment was going to start fist fights. But it's
winter in the northern hemisphere and we need something to do.
We have a student pilot who says that he is having trouble estimating
his altitude in the pattern. So instead shall we will advise him to
estimate angles? What this pilot really lacks is experience. What I
contend is that INITIALLY forcing him to see many "ideal" patterns,
i.e. repetition, is an important step in learning what a "normal"
pattern looks like and when the pattern is poorly flown, he will then
recognize it right away. Certainly, angles are part of what is being
learned but quantifying the angle is not required to learn. Of course
lift/sink, wind, low arrivals at the field, rope breaks, rock-offs, last
minute runway changes and buffoonery from the guy in the pattern in
front of him will force him to modify his pattern. My students are
trained to fly all of these problems without altimeter reference. But
initially, I begin by giving them a solid grounding in what "normal"
LOOKS LIKE.
As for our student who is trying to estimate his altitude, keep flying.
It will come all together.
Paul Corbett
ZZ
ask!
Paul
ZZ
Surfer! wrote:
In message , ZZ
writes
Tom:
Snip
familiar airfield. Is the reference point technique taught in the US?- Hide quoted text -
Old October 30th 09, 11:40 AM posted to rec.aviation.soaring
delboy
If you can estimate the distance and judge the angle, this fixes the
height - this is simple trigonometry.
In the UK we teach an exercise called the zig-zag circuit where the
instructor demonstrates a circuit starting at the right high key
distance, height and angle to the reference point, but allows the
gider to drift in so the low key point is reached at about the right
height, but much too close in. Thus the student can see that the
angle looks much too steep (the impression given is that you are much
too high, but you are not). Then you move back out until the angle
looks right and complete the circuit normally.
I do not disagree with ZZ that regular experience of what a circuit
should look like is a necessary part of training. Also learning to
judge what items on the ground, such as trees, vehicles and houses
look like from different heights.
Derek Copeland
P.S This is posted from Google Groups, as I can't seem to access
r.a.s. directly from gp.net. Is there a problem with my email address
or UK postings Andy?
Looking for TSO Altimeter Rob Turk Home Built 0 June 9th 07 03:52 PM
Altimeter off kevmor Instrument Flight Rules 11 March 26th 07 12:11 PM
Vector altitude for ILS below GS intercept altitude? M Instrument Flight Rules 23 May 20th 06 07:41 PM
GPS altitude vs altimeter altitude Chris W Piloting 37 April 19th 06 10:45 AM
Pressure Altitude or Density Altitude john smith Piloting 3 July 22nd 04 10:48 AM
