On Oct 28, 2:53*pm, db_sonic wrote:
I had a failed jack that I took apart to see why it was not maintaining the extended position. In my case the ramp would slowly lower back to collapsed postition, which besides annoying, can be a danger to the fuselage. *Turns out that it was the synthetic plunger on the main piston leaking. *So even under pressure the oil would seep past the plunger and the piston slowly looses position till it eventually collapses. *The culprit does not seem to be any of the various ball-bearings in the base of the jack. Anybody know if a replacement plunger could be obtained. *I am sure its much cheaper than a new jack. I took a look at a Cobra jack for a friend. It's not actually a "bottle jack" but more likely a replacement part for a "floor jack" - those long handled things on caster wheels you see in auto shops. The giveaway is the trunnions on the hydraulic cylinder which are not seen on mere bottle jacks. In the car jack application, "leak down" isn't an issue since it just has to hold long enough to put jack stands under the car after which the jack is lowered and removed. That makes me think that you will never get it to stop leaking. Scissor jacks are terrible since they have the least mechanical advantage when you need it most. The best solution I've seen is scissor jacks with the crank handle replaced with a large nut which the owner turns with a humongous slow speed cordless electric wrench bought specifically for the purpose. Bill D |
| Thread Tools | |
| Display Modes | |
| Cobra hydraulic bottle jacks - where to buy? | [email protected] | Soaring | 20 | August 17th 17 07:15 AM |
| WTB: Cobra Trailer Ramp Jack - US | Gary Emerson | Soaring | 1 | June 21st 09 02:34 AM |
| Cobra Hydraulic Jack | HL Falbaum[_2_] | Soaring | 4 | December 12th 08 09:45 PM |
| Cobra Hydraulic Jack - oil replentishment | Gary Emerson | Soaring | 4 | March 25th 05 07:47 PM |
| Cobra jack warning | Andy Durbin | Soaring | 8 | June 30th 04 03:32 AM |
