leading edge flaps
Old January 12th 04, 04:14 PM
Dudley Henriques
"Ed Rasimus" wrote in message
On Sun, 11 Jan 2004 23:36:55 GMT, "Dudley Henriques"
news
On Sun, 11 Jan 2004 06:05:28 -0600, "John Carrier"
If they extend when airpressure is reduced as airspeed slows, then it
would be redundant to add "also when a certain AOA is achieved"
because that is the inevitable, inexorable, undeniable result of
slowing.
Just musing here Ed; :-))))))
I might be missing something in what you're saying about slat extension
Ed,
but FWIW, although it's true that dynamic pressure will bring out an
aerodynamic LE slat as airspeed is reduced and angle of attack is
increased
as the result of that slowing, the only common denominator that SHOULD be
used for an aerodynamic slat extension parameter is aoa, not airspeed!
You are correct.
It's AOA, not specifically lower airspeed. They can droop under
acceleration when a design AOA is reached.
I got so wrapped up in trying to be all-encompassing while not
grabbing the tar baby that I mis-spoke.
I know the feeling. That ole' tar baby is one sticky character all right!
If you and Carrier ever manage to talk him into the back seat of a T38 for
just one flight......just ONE!!!.....I'll buy you both a case of Scotch if
you let me take him !! :-))
Dudley
Old January 12th 04, 04:29 PM
Tarver Engineering
snip
Now that you mention it, we did have Servair begging us to help them
interface new digital gyros to Houston's T-38Ns, but we rejected the work;
as the CCB system is too much overhaed. we offered a Part 25 type change,
but they did not understand.
FS - Propeller leading edge protective tape Sammy Home Built 0 July 6th 04 12:06 PM
Leading edge protection search Tim Hickey Home Built 0 June 28th 04 02:45 AM
A Bush C150? With Leading Edge Slats? [email protected] Home Built 33 May 27th 04 05:39 PM
-7 wing leading edge 'glitch' ? Charlie England Home Built 0 March 7th 04 12:27 AM
tail buffeting and leading edge fillets, strakes Wallace Berry Home Built 1 September 26th 03 10:48 PM
