![]() "Gord Beaman" wrote in message ... Ed Rasimus wrote: You are correct. It's AOA, not specifically lower airspeed. They can droop under acceleration when a design AOA is reached. I got so wrapped up in trying to be all-encompassing while not grabbing the tar baby that I mis-spoke. Ed Rasimus A gain of several notches. And isn't it so much nicer to have a civil professional discussion? |
![]() "Ed Rasimus" wrote in message news ![]() On 13 Jan 2004 06:58:46 -0800, (Frank Hitlaw) wrote: Dan, Tarver lost me with the fixed spoiler,what purpose would it serve on an aircraft.It would be pretty silly to have a spoiler fixed stowed or deployed. Then again you have to consider the source of this information.I am still looking for section 40 on Boeing aircraft. Frank M.Hitlaw Well, if we take the concept of "spoiler" as a device to destroy lift, and fixed as being a permanent, unmovable device, then we find examples on a lot of airliners. Look out the window at the top surface of the wing at those rows of little (about an inch high and four or five inches long) vortex generators. They are clearly spoilers of the smooth, lift-generating surface of the wing and they are fixed. Their function is to activate and energize the boundary layer and they actually keep smooth flow attached to the wing upper surface. Or, maybe we could consider wing fences on highly swept wing aircraft. They spoil span-wise flow and are definitely fixed. This thread is information rich. Too bad about the two noise generators. |
![]() "B2431" wrote in message ... From: (Frank Hitlaw) snip Dan, Tarver lost me with the fixed spoiler,what purpose would it serve on an aircraft.It would be pretty silly to have a spoiler fixed stowed or deployed. Then again you have to consider the source of this information.I am still looking for section 40 on Boeing aircraft. It's somewhere between the third and sixth cocktail. Why would either of you have a clue how an airplane is constructed? Do you see the irony of your posts? |
![]() "Frank Hitlaw" wrote in message om... Dan, Tarver lost me with the fixed spoiler,what purpose would it serve on an aircraft. I lost you with the full name of any control surface, Frank. |
FS - Propeller leading edge protective tape | Sammy | Home Built | 0 | July 6th 04 12:06 PM |
Leading edge protection search | Tim Hickey | Home Built | 0 | June 28th 04 02:45 AM |
A Bush C150? With Leading Edge Slats? | [email protected] | Home Built | 33 | May 27th 04 05:39 PM |
-7 wing leading edge 'glitch' ? | Charlie England | Home Built | 0 | March 7th 04 12:27 AM |
tail buffeting and leading edge fillets, strakes | Wallace Berry | Home Built | 1 | September 26th 03 10:48 PM |
