On my Kolb (Freebird calipers, Hegar master cylinders, no reservoir),
I attach tubing to the bleeder screw on the caliper which runs up to a funnel (made from a 1 liter soda bottle). I fill the funnel with brake fluid and hang it above the level of the master cylinders (let fluid run down to fill the tubing until it's full before attaching it to the bleeder screws on the calipers), open the bleeder screws at both ends, and go do something else until bubbles stop coming out the cylinder bleeder screws. No pumps required. -Dana On Tue, 3 Nov 2009 20:20:54 -0800 (PST), " wrote: On Nov 3, 5:01*pm, "Pintlar" wrote: Marchetti Sportster... . . . Are there any tricks to bleed the brakes on this homebuilt? Four master cylinders, one on each pedal, running to two 'T's, *where a single tube continues to each wing. *Thinking of *using a vacumn pump, to pull the fluid down to the caliper. Also, can anyone reccommend a good radio service shop in the Northwest? Reverse bleed .... from the brakes into the master cylinders? Works on lots of brake systems. ===================== Leon McAtee -- I don't trust a government I can't shoot back at. |
Engine bleeding | [email protected] | Piloting | 4 | December 9th 04 04:38 AM |
Engine bleeding | [email protected] | Piloting | 0 | December 8th 04 09:22 AM |
Engine bleeding | [email protected] | Piloting | 0 | December 8th 04 09:19 AM |
My squishy brake | JFLEISC | Owning | 0 | June 30th 04 01:44 AM |
Bleeding brakes on Tripacer | Corky Scott | Piloting | 2 | July 30th 03 08:11 PM |
