leading edge flaps
Old January 14th 04, 03:42 AM
Tarver Engineering
"John R Weiss" wrote in message
snip
If this is the case, the AOA at which the slats start to
deploy, and the rate at which they deploy, would likely be adjusted in the
design phase.
This is really good stuff, Weiss.
  #102
Old January 14th 04, 03:47 AM
Tarver Engineering
"John Mullen" wrote in message
snip
But hey - they saved a *lot* of time changing the engines that way.
(Wonder if JT was involved in that idea?)
The airline improvised their own way of completing a Douglas service
bulletin. It is a fact that the cause of the engine departure was some
dumbass mechanics ignoring Engineering.
The irony of your post is humorous, Mullen.
  #103
Old January 14th 04, 03:48 AM
Tarver Engineering
"Gord Beaman" wrote in message
snip
Apparently the chances of a wing engine failure plus an
asymmetric slat condition plus the left DC bus failure PLUS a
slat asym. warning failure was a pretty remote possibility.
Unless the Airline's mechanics ignore the Manufacturer's engineering, then
it is a certainty.
  #104
Old January 14th 04, 03:50 AM
Tarver Engineering
snip
Yes indeed, but then almost every aircraft accident is caused by
a string of problems, sometimes connected (as these were)
sometimes not.
Death is often the result, when mechanics shun engineering.
The irony of this branch of the thread is wonderful.
  #106
Old January 14th 04, 04:11 AM
Tarver Engineering
"B2431" wrote in message
And isn't it so much nicer to have a civil professional discussion?
Yes, real civil, tarver, without you.
More so than you deserve, little troll.
FS - Propeller leading edge protective tape Sammy Home Built 0 July 6th 04 12:06 PM
Leading edge protection search Tim Hickey Home Built 0 June 28th 04 02:45 AM
A Bush C150? With Leading Edge Slats? [email protected] Home Built 33 May 27th 04 05:39 PM
-7 wing leading edge 'glitch' ? Charlie England Home Built 0 March 7th 04 12:27 AM
tail buffeting and leading edge fillets, strakes Wallace Berry Home Built 1 September 26th 03 10:48 PM
