On Nov 23, 9:43*am, JJ Sinclair wrote:
I cut the head off some old junk instruments to make a perfect drilling jig. Have one cut off an 80mm and another cut off a 57mm instrument. Add another from an altimeter so's you get the cut out at 7 o'clock and your good to go. Helps in arranging things on the back of a new panel to see just where everything must go. Not all instruments are created equal..............measure twice, cut once! Cheers, JJ That's what I did. Tips: Use some wingtip around the flange until the shell fits tight in the new hole, which centers it and keeps it from moving while you're marking the holes. Use a centering punch to make precise marks for the holes. Also, a metal "hole reducer" from Aircraft Spruce will work in a pinch. Hope that helps, See ya, Dave "YO electric" |
On Nov 23, 10:34*am, Dave Nadler wrote:
On Nov 23, 9:43*am, JJ Sinclair wrote: I cut the head off some old junk instruments to make a perfect drilling jig. Have one cut off an 80mm and another cut off a 57mm instrument. Add another from an altimeter so's you get the cut out at 7 o'clock and your good to go. Helps in arranging things on the back of a new panel to see just where everything must go. Not all instruments are created equal..............measure twice, cut once! Cheers, JJ That's what I did. Tips: Use some wing-tape around the flange until the shell fits tight in the new hole, which centers it and keeps it from moving while you're marking the holes. Use a centering punch to make precise marks for the holes. Also, a metal "hole reducer" from Aircraft Spruce will work in a pinch. Hope that helps, See ya, Dave "YO electric" |
Drilling out old rivets questions? | Fonz | Home Built | 11 | August 12th 08 11:42 PM |
Hole template or Drawing for Altimeter | Craggy Aero | Home Built | 5 | November 15th 07 02:40 PM |
3 1/8" instrument template | [email protected] | Home Built | 4 | April 15th 06 02:26 AM |
Drilling a solid crankshaft | Ole Moyer | Home Built | 8 | November 2nd 05 05:17 AM |
LS3 flaperon gap seal template needed | Birdbones | Soaring | 2 | May 14th 05 12:46 AM |
