On Dec 17, 7:40 am, "Terry" wrote:
"Robert Moore" wrote in message 5.247... "Terry" wrote I know my C150 will fly with 20 degrees of flap. With 20 I can arrest the descent and climb out. In fact Terry, FAR Part 23 requires that your aircraft and all of the Cessna 150/152/172 series be able to execute a go-around at the maximum flap setting at the maximum TOGW. This requirement is what actually sets the maximum TOGW for these aircraft. Several years back, Cessna was able to raise the Maximum TOGW of the C- 172 by 100 lbs by simply removing the 40 degree flap setting. Section 23.77: Balked landing. (a) Each normal, utility, and acrobatic category reciprocating engine- powered airplane at 6,000 pounds or less maximum weight must be able to maintain a steady gradient of climb at sea level of at least 3.3 percent with- (1) Takeoff power on each engine; (2) The landing gear extended; (3) The wing flaps in the landing position, except that if the flaps may safely be retracted in two seconds or less without loss of altitude and without sudden changes of angle of attack, they may be retracted; and (4) A climb speed equal to VREF, as defined in 23.73(a). Bob Moore, ATP CFI PanAm (retired) Hi Bob Your correct in every aspect. I know what my airplane is capable of at or near gross. I know that I can climb at 30 degrees of flaps but not the 40 degrees that my C150 has. I was just trying to put some general guidelines into winter flying with an underpowered 100hp engine. I don't know if a new student or experience pilot such as yourself is reading this newsgroup. ![]() Terry N6401F I flew a Cessna 150 that had 40 deg flap, which was a hoot, the 152 only had 30 deg flaps. Though I've never had a flap problem I'll add that under some weather conditions, a cold a/c decending into humid air will frost up, I feel that could freeze the flaps. Ken |
On Dec 17, 1:05*pm, "Ken S. Tucker" wrote:
On Dec 17, 7:40 am, "Terry" wrote: "Robert Moore" wrote in message 85.247... "Terry" wrote I know my C150 will fly with 20 degrees of flap. With 20 I can arrest the descent and climb out. In fact Terry, FAR Part 23 requires that your aircraft and all of the Cessna 150/152/172 series be able to execute a go-around at the maximum flap setting at the maximum TOGW. This requirement is what actually sets the maximum TOGW for these aircraft. Several years back, Cessna was able to raise the Maximum TOGW of the C- 172 by 100 lbs by simply removing the 40 degree flap setting. Section 23.77: Balked landing. (a) Each normal, utility, and acrobatic category reciprocating engine- powered airplane at 6,000 pounds or less maximum weight must be able to maintain a steady gradient of climb at sea level of at least 3.3 percent with- (1) Takeoff power on each engine; (2) The landing gear extended; (3) The wing flaps in the landing position, except that if the flaps may safely be retracted in two seconds or less without loss of altitude and without sudden changes of angle of attack, they may be retracted; and (4) A climb speed equal to VREF, as defined in 23.73(a). Bob Moore, ATP CFI PanAm (retired) Hi Bob Your correct in every aspect. *I know what my airplane is capable of at or near gross. I know that I can climb at 30 degrees of flaps but not the 40 degrees that my C150 has. I was just trying to put some general guidelines into winter flying with an underpowered 100hp engine. *I don't know if a new student or experience pilot such as yourself is reading this newsgroup. * ![]() Terry N6401F I flew a Cessna 150 that had 40 deg flap, which was a hoot, the 152 only had 30 deg flaps. Though I've never had a flap problem I'll add that under some weather conditions, a cold a/c decending into humid air will frost up, I feel that could freeze the flaps. Ken Frost is a phenomenon that forms only in still air. And it wouldn't freeze the flaps. For frost to form, the aircraft surface cools through radiative cooling to below the air temperature when the dewpoint and temp are really close. When there's much wind the aircraft surface is kept at air temp through convection. Some old pilots used to burn off light frost just by taking off. That's now illegal in Canada. Ice, on the other hand, can form in flight but that flight has to be into fog or cloud or rain consisting of supercooled water droplets, which are below the freezing point but still liquid. Water can exist as a liquid down to -20°C. The airplane's surface will be below freezing because of the air temp, and any change in air temp will change the very light aircraft structure's temperature quickly. Dan |
![]() wrote The airplane's surface will be below freezing because of the air temp, and any change in air temp will change the very light aircraft structure's temperature quickly. Dan, Ken is back. He is afraid of flying anything but Microsoft Simulators. I have a feeling he is the same poster as Flaps50 and Flaps, or whoever the troll of a name close to that uses. Best advice is to ignore. He knows nothing of real airplanes, but likes to pretend that he does. I guess he has to be called down when he gives unsafe advice, though. I'll have to put him back in the kill file, since he snuck back in after my reformatting. -- Jim in NC |
On Thu, 17 Dec 2009 12:05:58 -0800 (PST), Ken S. Tucker wrote:
Ken caught trolling as Mark aka Marcus Aurelius Mark(ie) on Mark(ie): Retired aka lazy, bored and too stupid to do **** anymore - "I've since moved on to guitars, turbojets, alternative energy, and Victory gardens."~sci.physics Obese - "I have my own weight issues" ~misc.news.internet.discuss Troll/Forger - Admitted ~rec.aviation.piloting Philosopher - "Most people live lives of quiet desperation." ~alt.support.depression.manic BiPolar FukkNutzoid - "Its really less about how we got this way, and more about who we're going to become." ~alt.support.depression.manic Claims To Be Uber-Wealthy - "It's only $500,000 dollars..." ~misc.writing Brilliance...In His Own Mind - "But what makes me a creative genius.." ~misc.writing Founder of Art Academy - "Nor was it when I founded a school of the arts in my name..." ~misc.writing National Politician and Grand Entreprenuer - "convincing the chairman of the bank and head of the Georgia Republican party to fly to Washington, D.C. and within 3 days bring me a Small Business Admin.check for 350 thousand dollars." ~misc.writing Loved By Celebrities - "Mark Who Was Invited By Elvis To Graceland" ~signature several newsgroups ****sman - "Some cute little brunette named Tammy steal her boyfriend's car and credit cards and put me up on the 14th floor of the "Yachtsman" for a week in Myrtle Beach, while spending thousands by day, and smoking the sheets by night." ~misc.writing Google Profile - "I am a Renaissance Man. I'm still attempting things people think are impossible. I'm a dichotomy, a soft diamond, a militaristic saint, and always a very wise fool." -- Oh, the excitement! http://tr.im/1f9b |
On Dec 18, 10:52*am, Cliveden Chew Haas
wrote: On Thu, 17 Dec 2009 12:05:58 -0800 (PST), Ken S. Tucker wrote: Ken caught trolling as Mark aka Marcus Aurelius Mark(ie) on Mark(ie): Retired aka lazy, bored and too stupid to do **** anymore - "I've since moved on to guitars, turbojets, alternative energy, and Victory gardens."~sci.physics Obese - "I have my own weight issues" ~misc.news.internet.discuss Troll/Forger - Admitted ~rec.aviation.piloting Philosopher - "Most people live lives of quiet desperation." ~alt.support.depression.manic BiPolar FukkNutzoid - "Its really less about how we got this way, and more about who we're going to become." ~alt.support.depression.manic Claims To Be Uber-Wealthy - "It's only $500,000 dollars..." ~misc.writing Brilliance...In His Own Mind - "But what makes me a creative genius.." ~misc.writing Founder of Art Academy - "Nor was it when I founded a school of the arts in my name..." ~misc.writing National Politician and Grand Entreprenuer - "convincing the chairman of the bank and head of the Georgia Republican party to fly to Washington, D.C. and within 3 days bring me a Small Business Admin.check for 350 thousand dollars." ~misc.writing Loved By Celebrities - "Mark Who Was Invited By Elvis To Graceland" ~signature several newsgroups ****sman - "Some cute little brunette named Tammy steal her boyfriend's car and credit cards and put me up on the 14th floor of the "Yachtsman" for a week in Myrtle Beach, while spending thousands by day, and smoking the sheets by night." ~misc.writing Google Profile - "I am a Renaissance Man. I'm still attempting things people think are impossible. I'm a dichotomy, a soft diamond, a militaristic saint, and always a very wise fool." -- Oh, the excitement!http://tr.im/1f9b How fascinating. Tell us more about Me. What else have I done? I hope it's as exciting as this post! Next time make my dick 2 feet long. OK? --- Mark |
On Fri, 18 Dec 2009 09:05:09 -0800 (PST), Mark wrote:
On Dec 18, 10:52*am, Cliveden Chew Haas wrote: On Thu, 17 Dec 2009 12:05:58 -0800 (PST), Ken S. Tucker wrote: Ken caught trolling as Mark aka Marcus Aurelius Mark(ie) on Mark(ie): Retired aka lazy, bored and too stupid to do **** anymore - "I've since moved on to guitars, turbojets, alternative energy, and Victory gardens."~sci.physics Obese - "I have my own weight issues" ~misc.news.internet.discuss Troll/Forger - Admitted ~rec.aviation.piloting Philosopher - "Most people live lives of quiet desperation." ~alt.support.depression.manic BiPolar FukkNutzoid - "Its really less about how we got this way, and more about who we're going to become." ~alt.support.depression.manic Claims To Be Uber-Wealthy - "It's only $500,000 dollars..." ~misc.writing Brilliance...In His Own Mind - "But what makes me a creative genius.." ~misc.writing Founder of Art Academy - "Nor was it when I founded a school of the arts in my name..." ~misc.writing National Politician and Grand Entreprenuer - "convincing the chairman of the bank and head of the Georgia Republican party to fly to Washington, D.C. and within 3 days bring me a Small Business Admin.check for 350 thousand dollars." ~misc.writing Loved By Celebrities - "Mark Who Was Invited By Elvis To Graceland" ~signature several newsgroups ****sman - "Some cute little brunette named Tammy steal her boyfriend's car and credit cards and put me up on the 14th floor of the "Yachtsman" for a week in Myrtle Beach, while spending thousands by day, and smoking the sheets by night." ~misc.writing Google Profile - "I am a Renaissance Man. I'm still attempting things people think are impossible. I'm a dichotomy, a soft diamond, a militaristic saint, and always a very wise fool." -- Oh, the excitement!http://tr.im/1f9b How fascinating. Tell us more about Me. *PLONK* Mark, the Xposting asswipe. |
On Fri, 18 Dec 2009 10:52:47 -0500, Cliveden Chew Haas wrote:
On Thu, 17 Dec 2009 12:05:58 -0800 (PST), Ken S. Tucker wrote: Ken caught trolling as Mark aka Marcus Aurelius Mark(ie) on Mark(ie): Retired aka lazy, bored and too stupid to do **** anymore - "I've since moved on to guitars, turbojets, alternative energy, and Victory gardens."~sci.physics Obese - "I have my own weight issues" ~misc.news.internet.discuss Troll/Forger - Admitted ~rec.aviation.piloting Philosopher - "Most people live lives of quiet desperation." ~alt.support.depression.manic BiPolar FukkNutzoid - "Its really less about how we got this way, and more about who we're going to become." ~alt.support.depression.manic Claims To Be Uber-Wealthy - "It's only $500,000 dollars..." ~misc.writing Brilliance...In His Own Mind - "But what makes me a creative genius.." ~misc.writing Founder of Art Academy - "Nor was it when I founded a school of the arts in my name..." ~misc.writing National Politician and Grand Entreprenuer - "convincing the chairman of the bank and head of the Georgia Republican party to fly to Washington, D.C. and within 3 days bring me a Small Business Admin.check for 350 thousand dollars." ~misc.writing Loved By Celebrities - "Mark Who Was Invited By Elvis To Graceland" ~signature several newsgroups ****sman - "Some cute little brunette named Tammy steal her boyfriend's car and credit cards and put me up on the 14th floor of the "Yachtsman" for a week in Myrtle Beach, while spending thousands by day, and smoking the sheets by night." ~misc.writing Google Profile - "I am a Renaissance Man. I'm still attempting things people think are impossible. I'm a dichotomy, a soft diamond, a militaristic saint, and always a very wise fool." heh What a tool. |
More flaps? | WingFlaps | Piloting | 36 | May 26th 08 07:33 AM |
Almost no frozen tickets since the abysmal movie were pleasing alongside the fond wedding. | Hamid Bin Laden | Piloting | 0 | August 14th 07 04:17 AM |
Frozen airman's body headed home; remains identified from crash | Matt Barrow | Piloting | 1 | February 12th 06 11:18 PM |
floatplane - taking off frozen lake | Lets Fly | Piloting | 32 | December 8th 05 04:19 AM |
Frozen spoilers | stephanevdv | Soaring | 0 | November 4th 04 05:24 PM |
