On Jan 12, 5:08*pm, Martin Gregorie
wrote: On Tue, 12 Jan 2010 08:12:31 -0800, bildan wrote: On Jan 11, 6:56*pm, Martin Gregorie wrote: On Sun, 10 Jan 2010 12:47:53 -0800, Tom Gardner wrote: 2) If everyone turns their thermostats one degree closer to the outside temperature, drives a smaller car, and switches off phone chargers when not in use, will an energy crisis be averted? My sister pointed out recently that British people tend to keep their houses warmer than we did/do in NZ, so turning down the thermostat is not a hardship - just put on a pullover over your T-shirt in winter. Smaller cars is a problem for us in the trailer towing fraternity. My main gripe with the current crop of electric and hybrid cars is that nobody mentions towing, that I've seen anyway. There's one exception: Aptera say NO TOWING up front. I guess the same goes for many of the rest but they're too chicken to mention it. Hungry chargers are just stupidly bad technology and should be banned. Chargers that use no power[1] when they're plugged in but not connected to anything have been around for at least 8 years, so there's no excuse for selling one that burns power when its under no load. Anyway, I just looked at four chargers I happened to have handy and here's what it shows they burn when plugged into the mains and disconnected from the things they charge: 18 month old Lenovo laptop PSU (65w o/p) * * * *0 * watts. my much older Thinkpad 560Z PSU (54w o/p) * * * 1.9 watts. iPAQ 3630 PSU (10w o/p) * * * * * * * * * * * * 2.0 watts. 2001 Motorola T250 phone charger (2.5w o/p) * * 0 * watts. [1] I recently bought myself a power meter for a tenner from Maplins. It which reads to 0.1 watts, so a reading of 0.0 should mean 50 mW consumption or less. These power meters are simple to use: they have a 13 amp plug on the back and a 13 amp socket on the front, so you just plug them in between the wall and the device you want to measure. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | I suspect the concept of "powered trailers" will pop up more frequently.. *This is not an unproven concept since the mining industry has used it for years. If you use a load cell to measure the push-pull loads at the trailer hitch, the data can be used to control electric motors in the trailer wheels. *If a glider *trailer housed a large battery, possibly charged with a large solar panel on top and wheel motors, it could minimize the loads imposed on the towing vehicle by essentially powering itself. *The wheel motors would also provide regenerative braking. The whole car-trailer combo then becomes a parallel hybrid which permits the use of a much smaller and less powerful car. *The fuel savings while towing would be small compared to the fuel savings achieved by driving a small, fuel efficient yet tow capable car when not towing. The energy capacity of the trailer battery pack coupled to an inverter could also power things like power tools and polishers when parked at the airport. That sounds good, practical, even. I've seen film of power trailers behind Landrovers which seemed remarkably good at ploughing through mud in off-road tests. Do you know if there are stability problems with these rigs at highway speeds? I ask because I expect mining trailers would be somewhat slower and the film didn't show anything operating at much over 10 mph. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | I guess it could be done wrong so stability problems ensued. However, electric wheel motors create an opportunity for dynamic stability control. One motor could be instantly braked while the other powered forward to counter sway. Since the motors are directly coupled to the wheels, this could happen at the speed of electronics. Accelerometers in the trailer would sense sway. I would think it could be done in a way to create dead solid stability. |
bildan wrote:
That sounds good, practical, even. I've seen film of power trailers behind Landrovers which seemed remarkably good at ploughing through mud in off-road tests. Do you know if there are stability problems with these rigs at highway speeds? I ask because I expect mining trailers would be somewhat slower and the film didn't show anything operating at much over 10 mph. I guess it could be done wrong so stability problems ensued. However, electric wheel motors create an opportunity for dynamic stability control. One motor could be instantly braked while the other powered forward to counter sway. Since the motors are directly coupled to the wheels, this could happen at the speed of electronics. Accelerometers in the trailer would sense sway. I would think it could be done in a way to create dead solid stability. SparrowHawk owners, and maybe PW-5 owners, probably are looking forward to towing with EV! A lot of the glider pilots I know bring the glider over the mountains to Ephrata and leave it there all season, then take it home. They could borrow or rent a vehicle to do that, and use an EV or other high mpg car to go soaring the rest of the time. Pilots with self-launchers often avoid a lot of towing, since they can fly from a nearby airport instead driving to someplace with a tow plane, and don't need retrieves. Works for me. I like the idea of a powered trailer, though. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly |
contrails | No Name | Aviation Photos | 3 | June 22nd 07 01:47 PM |
Contrails | Darkwing | Piloting | 21 | March 23rd 07 05:58 PM |
Contrails | Kevin Dunlevy | Piloting | 4 | December 13th 06 08:31 PM |
Contrails | Steven P. McNicoll | Piloting | 17 | December 10th 03 10:23 PM |
