On Feb 15, 12:36*am, Mxsmanic wrote:
The topic of the thread concerns the high risk of attempting to return to an airport after losing all power after takeoff. It's hard to see how this would be applicable to gliders, since they do not take off and they are not powered. Winch rope breaks - aerotow rope breaks. I'm amused at the claim that gliders do not 'takeoff' and there's now a number of powered gliders out there.. Mixedups research stops at the GA gate |
george writes:
Winch rope breaks - aerotow rope breaks. Even then, it's not quite the same as being in a powered airplane. A glider is designed to fly without power; a powered aircraft is not. |
In rec.aviation.piloting Mxsmanic wrote:
george writes: Winch rope breaks - aerotow rope breaks. Even then, it's not quite the same as being in a powered airplane. A glider is designed to fly without power; a powered aircraft is not. Yep, powered aircraft stop flying and just flutter willy-nilly to the ground without power. -- Jim Pennino Remove .spam.sux to reply. |
Dallas wrote:
On Mon, 15 Feb 2010 17:10:00 -0000, wrote: The hero has to roll the airliner inverted to blow out the fire because "the wind is blowing faster on the top of the airplane than the bottom". Well of course silly.. don't you remember that from first day ground school? It's one the axioms of the Bernoulli principle. OMG, did I just see that on HBO? Was that "Turbulence" with the flight attendant landing the airplane? It was in a series called "Human Target". After the hero got the airplane inverted, the "flight computer" locked up and wouldn't let him return to normal flight, so he had to climb into the equipment compartment (unpressurized, at altitude, no oxygen) and have the handy, on-board nerd reboot the computer. -- Jim Pennino Remove .spam.sux to reply. |
Mxsmanic wrote:
george writes: Winch rope breaks - aerotow rope breaks. Even then, it's not quite the same as being in a powered airplane. A glider is designed to fly without power; a powered aircraft is not. The gliders power is provided by another a/c initially, and then it's switched to natural power in the form of gravity. If a "normally" poowered a/c was not designed to fly without power, it would drop like a stone when the engine is cut. It is not the engine that makes the a/c fly. It is the wings. The engine simply pulls the a/c through the air, as does gravity/inertia in the case of a glider. The only difference is that a glider is usually much lighter, and the wings longer. The glide ration, due to these differences is different to a powered a/c. The principles are the same. If a powered a/c loses power on take off, it lacks sufficient forward motion and altitude to maintain flight. When a glider loses power (it's tow plane), on take off, it lacks sufficient forward motion and altitude to maintain flight. Same same. Crash Lander -- |
Crash Lander writes:
If a "normally" poowered a/c was not designed to fly without power, it would drop like a stone when the engine is cut. Why? The same aerodynamics that help it to fly with power help it to glide without power. The only difference is that a glider is usually much lighter, and the wings longer. The glide ration, due to these differences is different to a powered a/c. The principles are the same. The difference in glide ratio is pretty important. I imagine that trying to turn around in a glider isn't particularly smart, either, just as it is extremely unwise in a powered airplane. But I don't know much about gliders. If a powered a/c loses power on take off, it lacks sufficient forward motion and altitude to maintain flight. When a glider loses power (it's tow plane), on take off, it lacks sufficient forward motion and altitude to maintain flight. Same same. In that case, the glider pilot should behave like the pilot of the powered aircraft, and look for a place to land ahead of him, instead of trying to turn around. |
either, It's SOP in gliders and regularly trained. In that case, the glider pilot should behave like the pilot of the powered aircraft, and look for a place to land ahead of him, instead of trying to turn around. BS. |
Did the impossible in my glider last night!!! | Bruno | Soaring | 4 | October 25th 09 02:53 PM |
Another impossible turn? | More_Flaps | Piloting | 4 | August 24th 08 01:38 PM |
Myth: 1 G barrel rolls are impossible. | Jim Logajan | Piloting | 244 | June 22nd 07 04:33 AM |
Impossible to ditch in a field (almost) | mindenpilot | Piloting | 29 | December 11th 04 11:45 PM |
bush: impossible to be AWOL (do vets give a sh!t) | B2431 | Military Aviation | 7 | September 8th 04 04:20 PM |
