Trucking companies are always looking to fill their trucks with
anything instead of "dead heading" them (running the trailer empty). Since you're looking for pretty much an empty truck, you may not know what - if anything - is going to happen until right before shipping. Not much fun. The alternate of booking the trailer in advance you will probably find more expensive than it's worth. Loading a car and glider trailer into a 48' or 53' trailer is not as simple as it may seem. Easiest with a "straight" trailer, not one with a "dance floor" like a moving van. You must arrange to load and unload at warehouses or loading docks which have ample room (and a shallow enough ramp angle) to maneuver the glider trailer from street level to dock height and into the truck. Plan to provide all the straps to secure the load. Most trucks have E-track in the walls, but there's no guarantee (it might even be a flatbed). The truck may show up with only load bars for load control, or straps which look like hell. Examine your car and trailer to find the best way to secure them. Some ways of strapping the car or trailer will make the suspension more rigid, so the contents might not ride as you'd prefer. You may need 4 or 6x 2" 3000+ Lb ratchet straps with hooks on the ends, then 2 E- track to D-ring adapters for each strap. I believe that to be legal on a flatbed requires three straps for each piece. You can probably return what you don't use, but may lose straps as you will not necessarily be there to load and unload. E-track, for example: http://www.uscargocontrol.com/etrack...655140931a03f1 Strap: http://www.uscargocontrol.com/ratche...afb8b38895e1ac D-ring adapter: http://www.uscargocontrol.com/etrack...655140931a03f1 or http://www.uscargocontrol.com/6etrac...737ca867b64b01 Also look at this site for any moving supplies you can imagine. www.newhaven-usa.com Start by contacting trucking companies in the Salt Lake area and around home. And here's one link for a starter. www.dead-heading.com/ Jim On Feb 16, 7:55*pm, GM wrote: Since we are on this subject: has anyone ever tried to ship a trailer/ passenger car combination in a 53ft van trailer? Does anyone know a shipping company that would do a load like this? I am still looking for a way to get my rig to UT without putting 4k miles on it and it should fit. Uli Neumann 'GM' |
On Feb 16, 9:43*pm, JS wrote:
* Trucking companies are always looking to fill their trucks with anything instead of "dead heading" them (running the trailer empty). Since you're looking for pretty much an empty truck, you may not know what - if anything - is going to happen until right before shipping. Not much fun. The alternate of booking the trailer in advance you will probably find more expensive than it's worth. * Loading a car and glider trailer into a 48' or 53' trailer is not as simple as it may seem. Easiest with a "straight" trailer, not one with a "dance floor" like a moving van. You must arrange to load and unload at warehouses or loading docks which have ample room (and a shallow enough ramp angle) to maneuver the glider trailer from street level to dock height and into the truck. Plan to provide all the straps to secure the load. Most trucks have E-track in the walls, but there's no guarantee (it might even be a flatbed). The truck may show up with only load bars for load control, or straps which look like hell. Examine your car and trailer to find the best way to secure them. Some ways of strapping the car or trailer will make the suspension more rigid, so the contents might not ride as you'd prefer. You may need 4 or 6x 2" 3000+ Lb ratchet straps with hooks on the ends, then 2 E- track to D-ring adapters for each strap. * I believe that to be legal on a flatbed requires three straps for each piece. You can probably return what you don't use, but may lose straps as you will not necessarily be there to load and unload. * E-track, for example:http://www.uscargocontrol.com/etrack...2.html?zenid=5... * Strap:http://www.uscargocontrol.com/ratche...083.html?zenid... * D-ring adapter:http://www.uscargocontrol.com/etrack...enid=53c9c95b2... * orwww.uscargocontrol.com/6etrackropetieoff-p-185.html?zenid=5f59e9288b3... * Also look at this site for any moving supplies you can imagine.www.newhaven-usa.com * Start by contacting trucking companies in the Salt Lake area and around home. And here's one link for a starter.www.dead-heading.com/ Jim On Feb 16, 7:55*pm, GM wrote: Since we are on this subject: has anyone ever tried to ship a trailer/ passenger car combination in a 53ft van trailer? Does anyone know a shipping company that would do a load like this? I am still looking for a way to get my rig to UT without putting 4k miles on it and it should fit. Uli Neumann 'GM' Seeing as most freight trucks get 6-7 at best mpg and average price of diesel is about $2.75 per gallon that's about .045 cents per mile just for fuel X 4000 miles or is that one way half 2000 miles even at $1 per mile that's $2K? I know I own and operate 10 of these guzziling beasts but I run tankers so unless you run your trailer through a blender and add water I couldn't help you. Now my diesel pick up (4 wheel drive Chevy) gets about 16 mpg that brings the operating cost to more like .17-.18 cents per mile. I've got a friend that runs freight vans all 48 states that's based in Las Vegas Nv. where's your trailer originating from? You might look for a flat bed that will haul a LTL. Much easier to secure a load on a flat bed. |
On Feb 17, 2:20*am, glidergeek wrote:
On Feb 16, 9:43*pm, JS wrote: * Trucking companies are always looking to fill their trucks with anything instead of "dead heading" them (running the trailer empty). Since you're looking for pretty much an empty truck, you may not know what - if anything - is going to happen until right before shipping. Not much fun. The alternate of booking the trailer in advance you will probably find more expensive than it's worth. * Loading a car and glider trailer into a 48' or 53' trailer is not as simple as it may seem. Easiest with a "straight" trailer, not one with a "dance floor" like a moving van. You must arrange to load and unload at warehouses or loading docks which have ample room (and a shallow enough ramp angle) to maneuver the glider trailer from street level to dock height and into the truck. Plan to provide all the straps to secure the load. Most trucks have E-track in the walls, but there's no guarantee (it might even be a flatbed). The truck may show up with only load bars for load control, or straps which look like hell. Examine your car and trailer to find the best way to secure them. Some ways of strapping the car or trailer will make the suspension more rigid, so the contents might not ride as you'd prefer. You may need 4 or 6x 2" 3000+ Lb ratchet straps with hooks on the ends, then 2 E- track to D-ring adapters for each strap. * I believe that to be legal on a flatbed requires three straps for each piece. You can probably return what you don't use, but may lose straps as you will not necessarily be there to load and unload. * E-track, for example:http://www.uscargocontrol.com/etrack...2.html?zenid=5... * Strap:http://www.uscargocontrol.com/ratche...083.html?zenid... * D-ring adapter:http://www.uscargocontrol.com/etrack...enid=53c9c95b2... * orwww.uscargocontrol.com/6etrackropetieoff-p-185.html?zenid=5f59e9288b3... * Also look at this site for any moving supplies you can imagine.www.newhaven-usa.com * Start by contacting trucking companies in the Salt Lake area and around home. And here's one link for a starter.www.dead-heading.com/ Jim On Feb 16, 7:55*pm, GM wrote: Since we are on this subject: has anyone ever tried to ship a trailer/ passenger car combination in a 53ft van trailer? Does anyone know a shipping company that would do a load like this? I am still looking for a way to get my rig to UT without putting 4k miles on it and it should fit. Uli Neumann 'GM' Seeing as most freight trucks get 6-7 at best mpg and average price of diesel is about $2.75 per gallon that's about .045 cents per mile just for fuel X 4000 miles or is that one way half 2000 miles even at $1 per mile that's $2K? I know I own and operate 10 of these guzziling beasts but I run tankers so unless you run your trailer through a blender and add water I couldn't help you. Now my diesel pick up (4 wheel drive Chevy) gets about 16 mpg that brings the operating cost to more like .17-.18 cents per mile. I've got a friend that runs freight vans all 48 states that's based in Las Vegas Nv. where's your trailer originating from? You might look for a flat bed that will haul a LTL. Much easier to secure a load on a flat bed.- Hide quoted text - - Show quoted text - JS and glidergeek, excellent info here! I am considering driving from SC to UT using my Diesel Jetta, which gets around 35mpg with a trailer at moderate speeds. My problem is that with the 'generous' allotment of vacation time we tend to get in the US, I am pretty much blowing all my days. I am figuring on about 3-4 days per leg (2,100miles). So my motive is to save time by sending the rig ahead and to pick it up on the other end. Decisions, decisions .... GM |
Golf Mike,
One of my cousins, who lives in SC, is an independent trucker that makes cross-country trips all the time. Some time in the past, I enquired about him hauling my glider trailer from NC to CA and it wasn't going to be cheap. Something like US$4.00 per mile, if I remember correctly. I suppose he would find his own load for the return trip. If you are interested, I can e-mail him and get a price. But as JS stated, you'll need to arrange for places where the rig can be loaded and unloaded. Ray Lovinggood Carrboro, North Carolina, USA |
On Feb 17, 8:07*am, GM wrote:
On Feb 17, 2:20*am, glidergeek wrote: On Feb 16, 9:43*pm, JS wrote: * Trucking companies are always looking to fill their trucks with anything instead of "dead heading" them (running the trailer empty). Since you're looking for pretty much an empty truck, you may not know what - if anything - is going to happen until right before shipping. Not much fun. The alternate of booking the trailer in advance you will probably find more expensive than it's worth. * Loading a car and glider trailer into a 48' or 53' trailer is not as simple as it may seem. Easiest with a "straight" trailer, not one with a "dance floor" like a moving van. You must arrange to load and unload at warehouses or loading docks which have ample room (and a shallow enough ramp angle) to maneuver the glider trailer from street level to dock height and into the truck. Plan to provide all the straps to secure the load. Most trucks have E-track in the walls, but there's no guarantee (it might even be a flatbed). The truck may show up with only load bars for load control, or straps which look like hell. Examine your car and trailer to find the best way to secure them. Some ways of strapping the car or trailer will make the suspension more rigid, so the contents might not ride as you'd prefer. You may need 4 or 6x 2" 3000+ Lb ratchet straps with hooks on the ends, then 2 E- track to D-ring adapters for each strap. * I believe that to be legal on a flatbed requires three straps for each piece. You can probably return what you don't use, but may lose straps as you will not necessarily be there to load and unload. * E-track, for example:http://www.uscargocontrol.com/etrack...2.html?zenid=5... * Strap:http://www.uscargocontrol.com/ratche...083.html?zenid... * D-ring adapter:http://www.uscargocontrol.com/etrack...enid=53c9c95b2... * orwww.uscargocontrol.com/6etrackropetieoff-p-185.html?zenid=5f59e9288b3... * Also look at this site for any moving supplies you can imagine.www.newhaven-usa.com * Start by contacting trucking companies in the Salt Lake area and around home. And here's one link for a starter.www.dead-heading.com/ Jim On Feb 16, 7:55*pm, GM wrote: Since we are on this subject: has anyone ever tried to ship a trailer/ passenger car combination in a 53ft van trailer? Does anyone know a shipping company that would do a load like this? I am still looking for a way to get my rig to UT without putting 4k miles on it and it should fit. Uli Neumann 'GM' Seeing as most freight trucks get 6-7 at best mpg and average price of diesel is about $2.75 per gallon that's about .045 cents per mile just for fuel X 4000 miles or is that one way half 2000 miles even at $1 per mile that's $2K? I know I own and operate 10 of these guzziling beasts but I run tankers so unless you run your trailer through a blender and add water I couldn't help you. Now my diesel pick up (4 wheel drive Chevy) gets about 16 mpg that brings the operating cost to more like .17-.18 cents per mile. I've got a friend that runs freight vans all 48 states that's based in Las Vegas Nv. where's your trailer originating from? You might look for a flat bed that will haul a LTL. Much easier to secure a load on a flat bed.- Hide quoted text - - Show quoted text - JS and glidergeek, excellent info here! I am considering driving from SC to UT using my Diesel Jetta, which gets around 35mpg with a trailer at moderate speeds. My problem is that with the 'generous' allotment of vacation time we tend to get in the US, I am pretty much blowing all my days. I am figuring on about 3-4 days per leg (2,100miles). So my motive is to save time by sending the rig ahead and to pick it up on the other end. Decisions, decisions .... GM- Hide quoted text - - Show quoted text - In exactly the same boat here - it's the "extra" days that kill any hope of SW or West Coast contests for me. The one alternative that I've toyed with is finding club member (retired, under-employed, independently wealthy) who is willing to do the drive in return for some flying time. I'm willing to let him/her have the aircraft for up to a week either side of a contest. Especially if they are willing to share a hotel room with you, the incremental cost of paying for their food and a few extra hotel nights is probably cheaper than any other alternative. Plus, you then have crew for the contest... |
Tim Mara's website has some pics of 2 304's shipped to oz in one
container on his website - 25/09/2004, http://www.wingsandwheels.com/Owners.htm. One trailer w glider is under with axle removed, the other, dismantled. Some pics of loading with forklift as well. |
![]() - Show quoted text - JS and glidergeek, excellent info here! I am considering driving from SC to UT using my Diesel Jetta, which gets around 35mpg with a trailer at moderate speeds. My problem is that with the 'generous' allotment of vacation time we tend to get in the US, I am pretty much blowing all my days. I am figuring on about 3-4 days per leg (2,100miles). So my motive is to save time by sending the rig ahead and to pick it up on the other end. Decisions, decisions .... GM- Hide quoted text - - Show quoted text - In exactly the same boat here - *it's the "extra" days that kill any hope of SW or West Coast contests for me. * The one alternative that I've toyed with is finding club member (retired, under-employed, independently wealthy) who is willing to do the drive in return for some flying time. *I'm willing to let him/her have the aircraft for up to a week either side of a contest. Especially if they are willing to share a hotel room with you, the incremental cost of paying for their food and a few extra hotel nights is probably cheaper than any other alternative. *Plus, you then have crew for the contest... Not to hijack the thread, but this is why we need east and west nationals in the USA. The racing committee ignores the data and the written comments from the last pole and has taken no steps to explore changing the US system. The comments from the last pole were clear that pilots are tired of driving or just don't drive to contests across the country because of cost and time involved. The US team is being selected from only those willing to drive long distances and have the vacation time to spend three weeks for a nationals. OK, off my soapbox and back to the original thread. |
Thread part one:
Thanks to all with info on how to win at Trailer Tetris, especially KS. I think it has scared my friend off the idea of two in a container. At least I won't need to pack it! Chocking and strapping one trailer in a container takes very little effort. Thread part two: The bets are on. My money is on GM and P3 getting someone else to drive their car/trailer to Parowan. P3 will certainly get a response to that offer! Hard to beat flying the Great Basin in the heat of the summer. (the look on HW's face after his first XC at Ely was priceless.) Jim Thread part three: On Feb 17, 10:26*am, Tim Taylor wrote: OK, off my soapbox and back to the original thread. |
On Feb 17, 8:48*pm, JS wrote:
Thread part one: * Thanks to all with info on how to win at Trailer Tetris, especially KS. I think it has scared my friend off the idea of two in a container. At least I won't need to pack it! Chocking and strapping one trailer in a container takes very little effort. Thread part two: * The bets are on. My money is on GM and P3 getting someone else to drive their car/trailer to Parowan. P3 will certainly get a response to that offer! Hard to beat flying the Great Basin in the heat of the summer. (the look on HW's face after his first XC at Ely was priceless.) Jim Thread part three: On Feb 17, 10:26*am, Tim Taylor wrote: OK, off my soapbox and back to the original thread.- Hide quoted text - - Show quoted text - Thanks for all the input, guys! Sorry to disappoint you, JS! I will bite the bullet and drive both ways with the help of my daughter, who will also crew for me in Parowan. Anyhow, I think a discussion about Eastern/Western Nationals is warranted. Even if we don't split it up like this, at least the dates should be picked such that the 4th of July weekend is somehow included to save prescious vacation time lest we want to turn the Nationals into an event that only independently rich or retired folks can attend regularly. Wait - let me get into my Nomex suit first .... ;-) GM |
Trailer tires for old (1981) Komet Trailer | [email protected] | Soaring | 3 | May 13th 09 10:24 PM |
DC-3 on a trailer | Glenn[_2_] | Aviation Photos | 1 | April 13th 08 03:21 PM |
WTB: 15m trailer, CA (USA) | John H. Campbell | Soaring | 0 | March 11th 04 03:47 AM |
FS: 2-33, 1-34, trailer | F.L. Whiteley | Soaring | 0 | February 16th 04 05:59 PM |
FS Trailer | Joseph L. Hyde | Soaring | 0 | January 11th 04 05:39 PM |
