Komet trailer tires
Old February 23rd 10, 10:57 AM posted to rec.aviation.soaring
Morgans[_2_]
Default Komet trailer tires
"HL Falbaum" wrote
Sway is more a function of the tow vehicle than anything else.
Demonstrated by towing same trailer, same road, same day, same speed--two
different vehicles, vastly different result.
If you don't believe that, try towing ANY trailer with an uber short
wheelbase, low overhang vehicle, like a Jeep. A Jeep CJ vehicle will make
ANY trailer sway, with any trailer weight and balance.
Jim in NC
Old February 24th 10, 03:44 AM posted to rec.aviation.soaring
GM
wheelbase, low overhang vehicle, like a Jeep. *A Jeep CJ vehicle will make
Jim in NC
That may be true for the CJ but I owned a 2-door Dodge 'Raider' aka
Mitsubishi 'Pajero'. This car had about the same dimensions as the CJ
but I towed my trailer from PA to CA and back without any sway
whatsoever. Good trailer tires and a good weight distribution in the
trailer plus the proper tounge weight are the key to happy trailering.
Uli
Old February 24th 10, 01:17 PM posted to rec.aviation.soaring
HL Falbaum[_2_]
"GM" wrote in message
speed--two
Jim in NC
Uli
Not to belabor the point, but the two vehicles in my experiment were similar
size, weight, overhang. The real difference was suspension stiffness. A soft
'98 Chevrolet Tahoe, and a (about same year) Ford Expedition. The Ford had a
stiffer suspension and more precise steering. The Chev was soft and more
"loose", the sway always started at about 70mph. The Tahoe was replaced with
a '03 Avalanche---stiffer suspension, tighter steering. Same trailer was
then towed without sway at any speed.
Hartley Falbaum
"KF" USA
Old February 24th 10, 03:46 PM posted to rec.aviation.soaring
mattm[_2_]
OK, so a proper fit between the hitch and ball is important, too.
What do I do with
my Cobra trailer that fits a 50mm ball? I actually *do* have a 50mm
ball but it has a
1" shank. However, my car has a 1.25" hitch receiver (factory
installed), and I can't
find any fittings that will take a 1" shank. For the moment I'm just
using a 1 7/8"
ball (47.6mm) since the trailer just goes from the tiedown to the end
of the runway,
and I've heard the horror stories of using a 2" ball (50.8mm). Any
ideas that don't
cost an arm and a leg (such as "buy a new car")?
-- Matt
Old February 24th 10, 04:26 PM posted to rec.aviation.soaring
HL Falbaum[_2_]
Matt;
It is a good idea to have options. So, if someone else has to come get you
with their car, they are likely to have a 1 7/8" or a 2" ball.
It would be easy to replace the hitch on the trailer with either a 2" or 1
7/8" . These are commonly available, just bolt on. Then sell the 50mm ball.
For little money, a welding shop could make a custom mount---50mm ball with
1" shank into 2"x 1/4"x 1/4" square tube, welded onto 1 1/4 " tubing stub
and insert into your receiver.
50mm hitch on 1 7/8" ball is just a little sloppy--probably a minor factor,
but best to change something.
Hartley Falbaum
"mattm" wrote in message
What do I do with
ball but it has a
using a 1 7/8"
of the runway,
ideas that don't
-- Matt
Old February 25th 10, 06:03 AM posted to rec.aviation.soaring
Morgans[_2_]
ball.
with 1" shank into 2"x 1/4"x 1/4" square tube, welded onto 1 1/4 " tubing
stub and insert into your receiver.
factor, but best to change something.
I agree. Get a welding shop (if you are not able to do it yourself) to
change out the trailer hitch for a standard size like 2". (standard in this
area, anyway) Also, custom fit the 1 1/4" stub to your receiver. I have
usually found they fit loose as crap, unless you do something to make it fit
right.
I had good luck doing this by running two beads of weld down the length of
the hitch stub on two adjacent sides of the stub, then grind it down to a
"just right - slide in, but no wobble" fit. It is amazing how that can
reduce sway, and quiet down the ride down the road.
Anyone else with a sway problem have a sloppy fitting hitch - receiver fit?
Anyone do something to tighten up the fit?
Jim in NC
Old February 25th 10, 01:49 PM posted to rec.aviation.soaring
vontresc
ball.
*I agree. *Get a welding shop (if you are not able to do it yourself) to
change out the trailer hitch for a standard size like 2". *(standard in this
area, anyway) *Also, custom fit the 1 1/4" stub to your receiver. *I have
right.
"just right - slide in, but no wobble" fit. *It is amazing how that can
Jim in NC
Ok there seems to be a lot of OWT, and other imprecise anecdotal
evidence about trailers and towing floating out there. Has anyone like
an AKAFLIEG group ever done some trailer dynamocs studies????
Peter
Old February 25th 10, 02:06 PM posted to rec.aviation.soaring
Burt Compton - Marfa
Yes, get an "anti-rattle" J bolt device for your receiver for about
$23. from Redtrailers.com
See it at http://www.redtrailers.com/ShowItem.asp?id=63201
You may need a shop to drill an extra hole in the side of your steel
hitch.
Includes a lock device.
A fellow Texas glider pilot suggested it. It tightens up nicely and
stops the rattling.
This must help with sway -- but I really don't have much sway because
I don't drive my glider trailers (5) over 60 MPH.
Burt
"The Turtle", just easin' on down the road
from Marfa, in southwest Texas, USA
Old February 25th 10, 02:28 PM posted to rec.aviation.soaring
HL Falbaum[_2_]
"Morgans" wrote in message
you with their car, they are likely to have a 1 7/8" or a 2" ball.
this area, anyway) Also, custom fit the 1 1/4" stub to your receiver. I
have usually found they fit loose as crap, unless you do something to make
it fit right.
fit? Anyone do something to tighten up the fit?
Jim in NC
At the suggestion of someone else, I drove large nails into the gap between
stub and receiver, to remove the "slop". Made absolutely no difference with
sway in the Tahoe.
As to driving slowly, I had to do that with the Tahoe. Sway started anyway
when I was passed by 75mph Semis.
Hartley Falbaum
Old February 26th 10, 03:52 AM posted to rec.aviation.soaring
Eric Greenwell
right.
It seems remarkable and counter-intuitive that even 1/8" (a lot more
than my hitches) of total slop at one end of a 30 foot long trailer
could have any influence at all. Since the tires are approximately in
the middle, that'd be only an 1/8" at the tail. My trailer is stable,
yet I can still see the tail wagging 1 to 3 inches at times as I'm
driving, far more than a loose hitch would cause.
Perhaps there were some other changes made at the same time, like
changing tire pressures, moving stuff around in the trailer?
Eric Greenwell - Washington State, USA (netto to net to email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz
Trailer tires for old (1981) Komet Trailer [email protected] Soaring 3 May 13th 09 10:24 PM
Old Komet Trailer thermalrider Soaring 7 October 11th 08 04:13 PM
Komet Trailer Gas Springs P. Corbett Soaring 4 March 11th 07 11:30 PM
Komet Trailer Rims Tim Hanke Soaring 6 February 28th 06 04:56 PM
Komet trailer strut John Shelton Soaring 5 November 15th 03 05:04 PM
