On Mar 16, 9:38*am, lanebush wrote:
I am researching the IS28B2 Lark for our club. *From what I can tell these aircraft reach their life limit around 2014. *Am I correct in this deduction? *The info is pretty scarce. *In fact I can not find a copy of EO-24 anywhere on the web. *If this is true, is everyone planning to convert to experimental catagory? *Am I correct in saying that under experimental catagory commercial operations will not be possible? Thanks for any input. XF Larks have gone through multiple life extensions, which have little or nothing to do with airframe hours, but do require calendar-based special inspections. It's more like a shelf-life. Anyone know if 35 years was the final extension? The example you are looking at apparently was built about 1978, but construction continued into the mid-1990's. There are a couple for sale on segelflug.de built in 1988 and 1989 priced at 8000E each. There are a couple of L-13's on there also you might look over if in your price range. FWIW, some Aussies did a study on three high-time Larks several years ago and presented to OSTIV. IIRC, they concluded aerobatics should be stopped at 14,500 hours. I know about one here in the US that had the skin separate from the spar due to water in the wings freezing and thawing in western Colorado. That was repaired and it is operating with a club in the south. Corrosion seems to have been the major shelf life concern as many were left tied out instead of protected. Frank Whiteley |
On Mar 16, 12:52*pm, Frank Whiteley wrote:
On Mar 16, 9:38*am, lanebush wrote: I am researching the IS28B2 Lark for our club. *From what I can tell these aircraft reach their life limit around 2014. *Am I correct in this deduction? *The info is pretty scarce. *In fact I can not find a copy of EO-24 anywhere on the web. *If this is true, is everyone planning to convert to experimental catagory? *Am I correct in saying that under experimental catagory commercial operations will not be possible? Thanks for any input. XF Larks have gone through multiple life extensions, which have little or nothing to do with airframe hours, but do require calendar-based special inspections. *It's more like a shelf-life. *Anyone know if 35 years was the final extension? *The example you are looking at apparently was built about 1978, but construction continued into the mid-1990's. *There are a couple for sale on segelflug.de built in 1988 and 1989 priced at 8000E each. *There are a couple of L-13's on there also you might look over if in your price range. FWIW, some Aussies did a study on three high-time Larks several years ago and presented to OSTIV. *IIRC, they concluded aerobatics should be stopped at 14,500 hours. *I know about one here in the US that had the skin separate from the spar due to water in the wings freezing and thawing in western Colorado. *That was repaired and it is operating with a club in the south. *Corrosion seems to have been the major shelf life concern as many were left tied out instead of protected. Frank Whiteley There's an L-13 in the SSA classifieds also. Frank |
On Mar 16, 2:54*pm, Frank Whiteley wrote:
There's an L-13 in the SSA classifieds also. I'd rather they buy our L-13, though I'll be sad to see it go: http://sosaglidingclub.com/blanik/ (Or pair of new K21s last season has cut in on her popularity) |
On Mar 16, 1:51*pm, "Rob.Russell" wrote:
On Mar 16, 2:54*pm, Frank Whiteley wrote: There's an L-13 in the SSA classifieds also. I'd rather they buy our L-13, though I'll be sad to see it go:http://sosaglidingclub.com/blanik/ (Or pair of new K21s last season has cut in on her popularity) I don't see it listed on sac.ca |
I hear they're doing a remake of Escape from New York...
On Mar 16, 4:03*pm, Frank Whiteley wrote:
On Mar 16, 1:51*pm, "Rob.Russell" wrote: I'd rather they buy our L-13, though I'll be sad to see it go:http://sosaglidingclub.com/blanik/ I don't see it listed on sac.ca I'll investigate to determine the relevant volunteer and ensure that his pay is appropriately docked. |
Grob 103 Twin II Life Extension | Mike McCarron[_2_] | Soaring | 2 | May 18th 09 01:15 PM |
Grob 103 Twin II Life Extension | Mike McCarron[_2_] | Soaring | 2 | May 18th 09 02:49 AM |
LS-6A and B life extension | JS | Soaring | 0 | December 8th 05 10:56 PM |
Life extension LS6 a-b | Stuart | Soaring | 1 | January 20th 05 05:16 AM |
Puchacz life extension | Janusz Kesik | Soaring | 0 | November 9th 03 09:49 AM |
