Grob 103 Twin II Life Extension
Old May 18th 09, 12:00 AM posted to rec.aviation.soaring
Mike McCarron[_2_]
Default Grob 103 Twin II Life Extension
I am looking for a source of the AD 92-190/2 SB 315-45/2 on the web without
luck. Anybody out there can help?
MC
Old May 18th 09, 01:52 AM posted to rec.aviation.soaring
For current AD's you can go to FAA.gov and look under the aircraft
tab. There you will find all sorts of good info including type
certificates and AD's.
Old May 18th 09, 02:49 AM posted to rec.aviation.soaring
tab. *There you will find all sorts of good info including type
You are actually looking for the LBA 92-190-2 that mandates the
Service Life Extension inspection at 3000, 6000, 9000, and 12000
hours. The LBA mentions the Grob SB 315/45 and 315/45-2. I could find
the LBA via Google, but could not find the referenced SB on the Grob
web page.
Check with the new Grob Rep in Moriarty NM
Grob 103 Twin II Life Extension Mike McCarron[_2_] Soaring 2 May 18th 09 01:15 PM
Grob Twin III Must read! [email protected] Soaring 3 June 9th 08 07:08 AM
LS-6A and B life extension JS Soaring 0 December 8th 05 10:56 PM
Life extension LS6 a-b Stuart Soaring 1 January 20th 05 05:16 AM
Puchacz life extension Janusz Kesik Soaring 0 November 9th 03 09:49 AM
