On Wed, 07 Apr 2010 19:56:31 -0400, Ernest Christley
wrote: wrote: 90 degrees above ambient? 200 max? That is the minimum required Can often be a lot hotter than that. Only isophthalic resin rated for 210F and Vynylester rated at 241F would even be close. None of the common epoxies are rated for that temperature. You would need a novolac based epoxy (special high temperature epoxy resin) Thin some JBWeld. Squish it into the glass between sheets of cellophane with a large socket or piece of pipe. A BADGE Resin (Bisphenol A DiGlycidyl Ether) resin is another one of the special high temperature epoxy resins. Good to about 500 |
On 4/7/2010 10:04 PM, wrote:
On Wed, 07 Apr 2010 19:56:31 -0400, Ernest Christley wrote: wrote: 90 degrees above ambient? 200 max? That is the minimum required Can often be a lot hotter than that. Only isophthalic resin rated for 210F and Vynylester rated at 241F would even be close. None of the common epoxies are rated for that temperature. You would need a novolac based epoxy (special high temperature epoxy resin) Thin some JBWeld. Squish it into the glass between sheets of cellophane with a large socket or piece of pipe. A BADGE Resin (Bisphenol A DiGlycidyl Ether) resin is another one of the special high temperature epoxy resins. Good to about 500 Come on, guys! How hot do you think the intake air can be and still have the motor run??? -- Richard Lamb http://www.home.earthlink.net/~cavelamb/ |
On Wed, 07 Apr 2010 22:19:44 -0500, cavelamb ""cavelamb\"@ X
earthlink.net" wrote: On 4/7/2010 10:04 PM, wrote: On Wed, 07 Apr 2010 19:56:31 -0400, Ernest Christley wrote: wrote: 90 degrees above ambient? 200 max? That is the minimum required Can often be a lot hotter than that. Only isophthalic resin rated for 210F and Vynylester rated at 241F would even be close. None of the common epoxies are rated for that temperature. You would need a novolac based epoxy (special high temperature epoxy resin) Thin some JBWeld. Squish it into the glass between sheets of cellophane with a large socket or piece of pipe. A BADGE Resin (Bisphenol A DiGlycidyl Ether) resin is another one of the special high temperature epoxy resins. Good to about 500 Come on, guys! How hot do you think the intake air can be and still have the motor run??? I forgot to say JB Weld is a BADGE resin- which is why I mentioned it. |
"cavelamb" ""cavelamb\"@ X earthlink.net" wrote in message
m... On 4/7/2010 10:04 PM, wrote: On Wed, 07 Apr 2010 19:56:31 -0400, Ernest Christley wrote: wrote: 90 degrees above ambient? 200 max? That is the minimum required Can often be a lot hotter than that. Only isophthalic resin rated for 210F and Vynylester rated at 241F would even be close. None of the common epoxies are rated for that temperature. You would need a novolac based epoxy (special high temperature epoxy resin) Thin some JBWeld. Squish it into the glass between sheets of cellophane with a large socket or piece of pipe. A BADGE Resin (Bisphenol A DiGlycidyl Ether) resin is another one of the special high temperature epoxy resins. Good to about 500 Come on, guys! How hot do you think the intake air can be and still have the motor run??? -- Richard Lamb http://www.home.earthlink.net/~cavelamb/ I was really wondering about that as well--and also doubting the required strength... Peter |
Peter Dohm wrote:
"cavelamb" ""cavelamb\"@ X earthlink.net" wrote in message Come on, guys! How hot do you think the intake air can be and still have the motor run??? I was really wondering about that as well--and also doubting the required strength... The air doesn't stick around long enough to GET hot...it's moving past in a hurry. However, the plenum is in direct mechanical contact with the hot parts of the engine. The airflow will help cool it, but there're still parts in direct contact. Ron Wanttaja |
On Apr 10, 6:26*pm, Ron Wanttaja wrote:
Peter Dohm wrote: "cavelamb" ""cavelamb\"@ X earthlink.net" wrote in message Come on, guys! How hot do you think the intake air can be and still have the motor run??? I was really wondering about that as well--and also doubting the required strength... The air doesn't stick around long enough to GET hot...it's moving past in a hurry. *However, the plenum is in direct mechanical contact with the hot parts of the engine. *The airflow will help cool it, but there're still parts in direct contact. Ron Wanttaja We're not talking about a composite heat muff? Are we? Surely, we're talking about the part that directs air into the carb? Ed |
intake air filter choices | Dick | Home Built | 8 | January 19th 07 03:06 PM |
Flexible air intake hose | abripl | Home Built | 10 | July 21st 06 04:11 AM |
Blackbird intake | Speed | Piloting | 5 | May 25th 05 07:52 PM |
Q. about Eurofighter intake | Alistair Gunn | Military Aviation | 1 | August 20th 04 06:58 AM |
Lycoming intake preheater | Dale Larsen | Home Built | 5 | June 6th 04 10:32 PM |
