Hello,
is anyone may confirm some type of crankcase internal crack cause oil pressure drop? thanks -- Pub: http://www.cd1d.com/ Philippe Vessaire Ò¿Ó¬ |
On Tue, 06 Apr 2010 09:36:32 +0200, Philippe
wrote: Hello, is anyone may confirm some type of crankcase internal crack cause oil pressure drop? thanks drain the oil and take the football off the bottom of the engine (oil sump) and have a look up inside using a thousand candle power spotlight. you can see it all before you. you just need to have a new gasket available for the sump to engine joint. as to the question. havent experienced it with my O-200 but with the spotlight and an inspection mirror you should be able to confirm the suspicion or put your mind at ease. Stealth Pilot |
le mardi 6 avril 2010 13:00, Stealth Pilot s'est penché sur son
écritoire numérique et a écrit: drain the oil and take the football off the bottom of the engine (oil sump) and have a look up inside using a thousand candle power spotlight. you can see it all before you. you just need to have a new gasket available for the sump to engine joint. thanks for the answer... I will do. -- Pub: http://www.cd1d.com/ Philippe Vessaire Ò¿Ó¬ |
On Apr 6, 5:00*am, Stealth Pilot
wrote: On Tue, 06 Apr 2010 09:36:32 +0200, Philippe * wrote: Hello, *is anyone may confirm some type of crankcase internal crack cause oil pressure drop? thanks drain the oil and take the football off the bottom of the engine (oil sump) and have a look up inside using a thousand candle power spotlight. you can see it all before you. you just need to have a new gasket available for the sump to engine joint. as to the question. havent experienced it with my O-200 but with the spotlight and an inspection mirror you should be able to confirm the suspicion or put your mind at ease. Stealth Pilot Low oil pressure in a small Continental is usually due either to worn bearings, a worn oil pump, a loose oil pump cover, or a sticking oil pressure relief valve and maybe a broken relief valve spring. I'd take the accessory cover off first (while that oil tank is off) and check out the pump. The relief valve is under a brass acorn- headed plug on the RH side of the accessory case. Dan |
O200 titan cylinders | Philippe Vessaire[_3_] | Home Built | 7 | November 4th 08 06:10 PM |
O200 cylinder | Philippe Vessaire[_3_] | Home Built | 3 | October 19th 08 11:21 AM |
O200 engine | Philippe Vessaire | Home Built | 7 | August 17th 07 08:53 PM |
O200 nose | Philippe | Home Built | 0 | July 22nd 05 08:09 PM |
High Oil Pressure (was: Low oil pressure, high oil temp?) | Thomas Ploch | Owning | 4 | October 5th 04 04:34 AM |
