Front Electric Sustainer
Old April 17th 10, 02:54 PM posted to rec.aviation.soaring
vontresc
Default Front Electric Sustainer
On Apr 17, 7:44*am, "Paul Remde" wrote:
Hi,
It does look like a very elegant system.
I just thought of one other benefit of the system..... *If your tow release
fails, you may be able to cut it with the propeller... : ) *or perhaps you
would reel-in the rope and catch up with the towplane. *If the towpilot then
releases at just the right moment you could slingshot up another couple
hundred feet! *... OK, my mind is wandering in strange directions this
morning...
Paul Remde
"Greg Arnold" wrote in message
I see that the webpage now has pictures of the latest design, with a bigger
prop, and a more streamlined attachment to the spinner. *Also a video of it
running at Aero.
After the flight tests this summer, it will be interesting to get
information about its real world climb rate and range.
http://www.front-electric-sustainer.com
I'm thinking a bungee/sustainer launch would be fun. Use the bungee to
get the initial altitude, and then fire up the sustainer...
Pete
Front Electric Sustainer LimaZulu Soaring 25 November 3rd 09 02:25 PM
The HPH 304S Turbine sustainer glider kd6veb Soaring 2 September 23rd 09 05:10 AM
would an electric sustainer be practical Brad[_2_] Soaring 7 July 24th 09 06:29 PM
Sustainer engine ignition noise (Solo2350) Per Soaring 8 January 4th 07 05:56 AM
DG goes the sustainer option. Paul Soaring 25 June 4th 04 12:16 AM
