On Apr 27, 2:09*pm, Scott Alexander
wrote: The forecast tommorow looks fantastic down here in Memphis! *Looks like perfect conditions to load up on water. My guess is that the clear plastic peice is for sealing. *The cirrus wasn't designed with bags, it was designed with fiberglass water tanks. *The water ballast bags are an aftermarket addition. No experience with this particular installation but many years expeience with bags. If both the holes you describe are in the part of the root rib that closes the D tube then my guess is that the bags are fed in the large hole and then the fill/dump tube is brought out through the small hole. Explanation obviously wrong if the dump ports are in the wings not the fuselage. I doubt there are many ballast bag installations that remained exactly as the factory intended. I consider adding piccolo pipes an almost essential modification. No one who ever experienced a pinched off bag failing to dump would ague with this. Figuring this out and testing the system is probably not the best use of the few hours you have before your flight attempt. Andy |
Libelle 301 water ballast | [email protected] | Soaring | 3 | January 15th 08 02:40 PM |
Who first used water ballast and when? | John McCullagh | Soaring | 9 | October 18th 06 09:36 AM |
Water Ballast Upgrade | P.Corbett | Soaring | 5 | December 5th 05 02:32 PM |
water ballast leak | Robert Harvey | Soaring | 0 | May 26th 05 10:33 PM |
PW-5 Diamond Goal Flights | Dick Johnson | Soaring | 2 | November 17th 03 01:44 AM |
