On Apr 28, 7:02*pm, ryanglover1969 wrote:
I have a question for all the electronically minded pilots out there. Every time I transmit my vario goes crazy. The funny thing is that when the colibri and or the Ipaq isn't connected it doesn't go crazy. My set up is as follows: LX 1600vario * * * * * * * * * * * * * * * * * * Dittle FSG 2T radio * * * * * * * * * * * * * * * * * * Colibri data logger * * * * * * * * * * * * * * * * * * Ipaq 3600 running SeeYou mobile What's the solution? I got some ferrite beads and put them in various locations with no success. should I shield the cables from the vario to the colibri and Ipaq??? Ryan, have you checked the stability of your power supply? I run a very similar set-up: Becker 3201, LX20, LX1600 and an iPAQ but have a very good battery. Place a digital voltmeter between and a digital ampere- meter inline (both with min.-max hold function) with the power leads and key the microphone. There is a good chance that the power supply collapses momentarily below the minimum required to run everything properly. Uli |
Zaon MRX causing radio interference 2 | Itsaplane[_2_] | Soaring | 17 | August 2nd 09 02:51 PM |
FM radio interference from planes | rb | Piloting | 34 | July 19th 06 05:53 PM |
GPS / radio interference | Cub Driver | Piloting | 2 | October 31st 04 10:57 PM |
radio / vario interference - HELP! | Chris Davison | Soaring | 13 | November 3rd 03 06:09 AM |
Radio Interference Information | Ross Richardson | Piloting | 0 | October 17th 03 02:06 PM |
