I'm starting a new thread on this topic as the old one sort of drifted
off-topic and its conclusions don't seem to reflect what I've found... I have a Zaon MRX which is *using external ship's power* which is causing radio interference. I know it's the Zaon because when the radio goes to static, in flight, as if the squelch wasn't adjusted, turning off the Zaon immediately stops the problem. Following the recommendations of this forum, I've installed one, then two, then three ferrite cores on the Zaon end of the power cord. Each additional core has reduced the number of static problems I've had, but not to zero (and not to where I don't have to frequently turn the damned thing off!). Calling Zaon tech support today (800-496-9430 x-311/312), they say they have a particular problem with sailplanes -- something about our radios being particulary sensitive because they're low power compared to a larger, standard GA unit on a power plane. As such, they don't have any real solutions for running with external power. He did suggest either a) trying more ferrite cores on the Zaon power lead (!), b) trying a ferrite core on the negative (?) side of the radio's power lead, or for the sure fix c) running the Zaon off its internal battery or a *separate* external battery other than the one driving the radio. Anybody have any other suggestions? Eric |
Eric,
We have installed our MRX in the panel, and so far without issues. I put one large dia (non split) ferrite on the power line to to MRX. Ferrites are designed to work at a particular range of frequencies, so you might look into that. Also, run the power line through the core 3-4 times. each time improves noise suppression. Don't use the clamp on half shell type ferrites because if the two halves are not contacting, the ferrite does not do it's job. Otherwise, turn the squelch up! ;-) Matt |
I have the same problem. The Becker radio has a separate battery
though. I have not tried ferrite cores. What I found was I could stop the problem by applying inward pressure on the power cable, but once I released the pressure it was back to unsquelched radio. It stops also if I move the unit further away from the radio. I cannot figure out why the problem is intermittent. I would think it would constantly cause interference, but it comes and goes. I'd be interested to know if yours stops with pressure applied to the plug. I have not tried adjusting radio squelch settings as the radio is at the bottom of the stack and the adjuster is buried within. And I cannot force the problem to happen on the ground. Bob |
Itsaplane wrote:
As such, they don't have any real solutions for running with external power. He did suggest either a) trying more ferrite cores on the Zaon power lead (!), b) trying a ferrite core on the negative (?) side of the radio's power lead, or for the sure fix c) running the Zaon off its internal battery or a *separate* external battery other than the one driving the radio. 1) Does the static problem go away when you use it's internal battery? If it doesn't, your problem isn't the power lead and could be a radio wiring problem, or maybe an MRX defect. 2) Have you tried another MRX to see if it has the same problem? Try to borrow the newest one you can find, as the older ones did not have as much "rf emission control". 3) Run a new power lead to the MRX directly from the battery terminals, using shielded, twisted pair cable. Connect the shield to the negative (-) terminal on the battery, along with the negative lead. Don't connect the shield to anything at the MRX end. I believe this cable from Radio Shack will work: $9.89 50-Ft. Audio Cable - RadioShack.com 50-Ft. Audio Cable Model: CL2 UL Approved | Catalog #: 278-513 Do the simplest - but still safe - installation to test the idea. You can do permanent installation it works, including fusing the lead at the battery. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * Sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On Jul 22, 2:32*pm, Eric Greenwell wrote:
Itsaplane wrote: * As such, they don't have any real solutions for running with external power. * He did suggest either a) trying more ferrite cores on the Zaon power lead (!), b) trying a ferrite core on the negative (?) side of the radio's power lead, or for the sure fix c) running the Zaon off its internal battery or a *separate* external battery other than the one driving the radio. 1) Does the static problem go away when you use it's internal battery? If it doesn't, your problem isn't the power lead and could be a radio wiring problem, or maybe an MRX defect. 2) Have you tried another MRX to see if it has the same problem? Try to borrow the newest one you can find, as the older ones did not have as much "rf emission control". 3) Run a new power lead to the MRX directly from the battery terminals, using shielded, twisted pair cable. Connect the shield to the negative (-) terminal on the battery, along with the negative lead. Don't connect the shield to anything at the MRX end. I believe this cable from Radio Shack will work: $9.89 50-Ft. Audio Cable - RadioShack.com * * * * * * * * 50-Ft. Audio Cable Model: CL2 UL Approved *| *Catalog #: 278-513 Do the simplest - but still safe - installation to test the idea. You can do permanent installation it works, including fusing the lead at the battery. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes"http://tinyurl.com/y739x4 * * * Sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org I too have the Radio/Mrx intermittent squelch problem, as do 3 or more of my club members; all of us are using an external battery source, not all of us have a transponder, so I don’t think the transponder is the problem. In my particular case, I'm using a separate/ dedicated battery with shielded cable to power the MRX & Transponder. A few observations: 1) The separate battery for my Mrx is not fully isolated as Eric suggested above, but it is fully shielded up to the Positive and ground busses at the panel, and the Mrx unit has been serviced and upgraded recently. 2) The squelch problem does not occur when the internal battery is used on the Mrx. 3) I’ve noticed, for example, I can be on 123.3 when the squelch interference occurs however if I quickly switch to 123.5 or any other frequency no open squelch is detected. I can then go back on the original 123.3 freq. and the squelch problem is still occurring. This odd Mrx squelch interference behavior has also occurred on other frequencies, a complete mystery to me. Perhaps a full isolation of the Mrx external power system will be my next step as I’ve nearly run out of ideas. We seem to have a deep pool of smart minds here; perhaps someone will be able to take up the challenge of this annoying mystery that Zaon has so far failed to do. 21 |
Rick:
There is nothing surprising about what you describe. That is how harmonic interference is likely to play out. Let's say for instance that the MRX has a 9.5 Mhz microprocessor clock; the 13th harmonic of that would be 123.50 Mhz. But microprocessor oscillators don't need to be perfectly precise. If yours happens to be low by 0.2% then yours falls on 123.30 and someone else will find interference on another nearby frequency or not at all if the 13th harmonic happens to land right between radio channels or on a frequency that pilot B never tunes in. I have an MRX with sloppy external power connections and have never had interference; so maybe I am the pilot B case. Of course, I don't really know what clock freqencies are actually used in the MRX and I don't know which harmonic is the nasty in this case -- my numbers are just for illustration. Bob: The business of pushing on the connector is most likely that your fingers are capacitively coupling into the spurious radio propogation path between the MRX and radio. The propogation path is shunted or in some manner altered enough to make a big difference in the interference that you are hearing. I'll bet that if you just squeezed the connector without pushing you would find the same effect. Steve Koerner (retired EE) |
![]() "Itsaplane" wrote in message ... I'm starting a new thread on this topic as the old one sort of drifted off-topic and its conclusions don't seem to reflect what I've found... I have a Zaon MRX which is *using external ship's power* which is causing radio interference. I know it's the Zaon because when the radio goes to static, in flight, as if the squelch wasn't adjusted, turning off the Zaon immediately stops the problem. Following the recommendations of this forum, I've installed one, then two, then three ferrite cores on the Zaon end of the power cord. Each additional core has reduced the number of static problems I've had, but not to zero (and not to where I don't have to frequently turn the damned thing off!). Calling Zaon tech support today (800-496-9430 x-311/312), they say they have a particular problem with sailplanes -- something about our radios being particulary sensitive because they're low power compared to a larger, standard GA unit on a power plane. As such, they don't have any real solutions for running with external power. He did suggest either a) trying more ferrite cores on the Zaon power lead (!), b) trying a ferrite core on the negative (?) side of the radio's power lead, or for the sure fix c) running the Zaon off its internal battery or a *separate* external battery other than the one driving the radio. Anybody have any other suggestions? Eric Has anyone tried a cap across the power leads right at the Zaon's case? I don't know what the connectors are like, so I don't know how close you can go. Inside the power connector would be ideal. But a 25 volt or higher .01 uF in parallel with a .001 uF might help, and shouldn't hurt anything at DC. Tim Ward |
On Jul 23, 12:50*am, "Tim Ward" wrote:
"Itsaplane" wrote in message ... I'm starting a new thread on this topic as the old one sort of drifted off-topic and its conclusions don't seem to reflect what I've found... I have a Zaon MRX which is *using external ship's power* which is causing radio interference. *I know it's the Zaon because when the radio goes to static, in flight, as if the squelch wasn't adjusted, turning off the Zaon immediately stops the problem. Following the recommendations of this forum, I've installed one, then two, then three ferrite cores on the Zaon end of the power cord. *Each additional core has reduced the number of static problems I've had, but not to zero (and not to where I don't have to frequently turn the damned thing off!). Calling Zaon tech support today (800-496-9430 x-311/312), they say they have a particular problem with sailplanes -- something about our radios being particulary sensitive because they're low power compared to a larger, standard GA unit on a power plane. As such, they don't have any real solutions for running with external power. * He did suggest either a) trying more ferrite cores on the Zaon power lead (!), b) trying a ferrite core on the negative (?) side of the radio's power lead, or for the sure fix c) running the Zaon off its internal battery or a *separate* external battery other than the one driving the radio. Anybody have any other suggestions? Eric Has anyone tried a cap across the power leads right at the Zaon's case? I don't know what the connectors are like, so I don't know how close you can go. Inside the power connector would be ideal. But a 25 volt or higher .01 uF in parallel with a .001 uF might help, and shouldn't hurt anything at DC. Tim Ward Tim, are you recommending a polarized .01 and a ceramic .001? I, too, have the dreaded ZAON issues. Thanks, Tim Larsen |
On Jul 23, 4:06*pm, qflyer1 wrote:
On Jul 23, 12:50*am, "Tim Ward" wrote: "Itsaplane" wrote in message .... I'm starting a new thread on this topic as the old one sort of drifted off-topic and its conclusions don't seem to reflect what I've found.... I have a Zaon MRX which is *using external ship's power* which is causing radio interference. *I know it's the Zaon because when the radio goes to static, in flight, as if the squelch wasn't adjusted, turning off the Zaon immediately stops the problem. Following the recommendations of this forum, I've installed one, then two, then three ferrite cores on the Zaon end of the power cord. *Each additional core has reduced the number of static problems I've had, but not to zero (and not to where I don't have to frequently turn the damned thing off!). Calling Zaon tech support today (800-496-9430 x-311/312), they say they have a particular problem with sailplanes -- something about our radios being particulary sensitive because they're low power compared to a larger, standard GA unit on a power plane. As such, they don't have any real solutions for running with external power. * He did suggest either a) trying more ferrite cores on the Zaon power lead (!), b) trying a ferrite core on the negative (?) side of the radio's power lead, or for the sure fix c) running the Zaon off its internal battery or a *separate* external battery other than the one driving the radio. Anybody have any other suggestions? Eric Has anyone tried a cap across the power leads right at the Zaon's case? I don't know what the connectors are like, so I don't know how close you can go. Inside the power connector would be ideal. But a 25 volt or higher .01 uF in parallel with a .001 uF might help, and shouldn't hurt anything at DC. Tim Ward Tim, are you recommending a polarized .01 and a ceramic .001? I, too, have the dreaded ZAON issues. Thanks, Tim Larsen At RF frequencies you want a ceramic capacitor. As has been suggested here before by others you may also want to split the power leads and feed through separate ferrite chokes so you are filtering differential mode noise as sell. Although feeding both though a small ferrite choke solved my RF interference problems. Darryl |
![]() "qflyer1" wrote in message ... On Jul 23, 12:50 am, "Tim Ward" wrote: "Itsaplane" wrote in message ... I'm starting a new thread on this topic as the old one sort of drifted off-topic and its conclusions don't seem to reflect what I've found... I have a Zaon MRX which is *using external ship's power* which is causing radio interference. I know it's the Zaon because when the radio goes to static, in flight, as if the squelch wasn't adjusted, turning off the Zaon immediately stops the problem. Following the recommendations of this forum, I've installed one, then two, then three ferrite cores on the Zaon end of the power cord. Each additional core has reduced the number of static problems I've had, but not to zero (and not to where I don't have to frequently turn the damned thing off!). Calling Zaon tech support today (800-496-9430 x-311/312), they say they have a particular problem with sailplanes -- something about our radios being particulary sensitive because they're low power compared to a larger, standard GA unit on a power plane. As such, they don't have any real solutions for running with external power. He did suggest either a) trying more ferrite cores on the Zaon power lead (!), b) trying a ferrite core on the negative (?) side of the radio's power lead, or for the sure fix c) running the Zaon off its internal battery or a *separate* external battery other than the one driving the radio. Anybody have any other suggestions? Eric Has anyone tried a cap across the power leads right at the Zaon's case? I don't know what the connectors are like, so I don't know how close you can go. Inside the power connector would be ideal. But a 25 volt or higher .01 uF in parallel with a .001 uF might help, and shouldn't hurt anything at DC. Tim Ward Tim, are you recommending a polarized .01 and a ceramic .001? I, too, have the dreaded ZAON issues. Thanks, Tim Larsen Actually, I was thinking of a couple of ceramic surface mount chip caps inside the power connector. But having looked at the Zaon input power specs of 40 Vdc, I might go for 50 V caps. However, since this is connected to wiring that doesn't have an alternator to drive the voltage up and put spikes on it, you could make the case that 16 wvdc would be okay. I don't own a Zaon, have never attempted this, attempt at your own risk, etc. But in theory, it shouldn't hurt anything. Tim Ward |
Zaon MRX causing radio interference | [email protected] | Soaring | 16 | March 26th 09 06:49 PM |
FM radio interference from planes | rb | Piloting | 34 | July 19th 06 05:53 PM |
GPS / radio interference | Cub Driver | Piloting | 2 | October 31st 04 10:57 PM |
radio / vario interference - HELP! | Chris Davison | Soaring | 13 | November 3rd 03 06:09 AM |
Radio Interference Information | Ross Richardson | Piloting | 0 | October 17th 03 02:06 PM |
