contest task explanations .....
Old May 18th 10, 08:03 PM posted to rec.aviation.soaring
Ron Gleason
Default contest task explanations .....
On May 18, 11:43*am, John Seaborn wrote:
Try this. In the National rules (ssa.orgSailplane RacingRules) in
the back is an explanation and illustrations of how the tasks work. It
sounds like to have seen this already but take a close look at the
task illustrations. If you have specific questions post them here and
the RAS brain trust will help out.
Contest flying is really a great way to learn and improve XC skills.
John Seaborn
Sorry for all the replies but just found what I was looking for. The
illustrations are in Appendix A within all the 2010 rules books.
Thanks again
Old May 19th 10, 04:52 AM posted to rec.aviation.soaring
Frank[_12_]
John Seaborn
Sorry for all the replies but just found what I was looking for. *The
Thanks again
As you read the explanations, keep in mind that the Assigned Task is
actually an Assigned Area Task (Turn Area Task) with all turnpoint
radii set to 1 mile. Two pilots flying the same "Assigned Task" can
actually wind up with distinctly different mileages if one pilot just
nicks the front edge of each turnpoint cylinder while the other goes
to the back of each one. Visualize a 'cats cradle' AT with 5
turnpoints. The 'long' pilot will actually fly 10 miles further than
the 'short' one.
Regards,
Frank
Task Building Uncle Fuzzy Soaring 5 August 5th 09 08:09 PM
How to be a Task-setter / CD noel.wade Soaring 5 September 27th 08 02:00 AM
New DMSt task: 4 TPs Klaus T. Soaring 0 January 9th 06 12:03 AM
New Task JJ Sinclair Soaring 5 October 23rd 03 01:36 AM
contest task completion rates? ken ward Soaring 2 August 11th 03 03:32 AM
