"David Lesher" wrote in message
... It might be interesting to take a container with some small quantity of gas-damp kitty litter and ignite it safely -- ie well clear of any burnable stuph and with a 6' pole to set it off. The kitty litter won't burn. The gas fumes will, and I'd assume will the heat will evaporate 'trapped' gas....but slowly. Just use the fuel soaked kitty litter in the litter box. It will keep your cat from smoking! ;-) Avgas or auto fuel will smell better than the used litter box. |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
Protecting fiberglass from fuel & oil | Paul Lee | Home Built | 2 | September 18th 03 06:14 AM |
Fuel pressure Problems | smf | Home Built | 3 | September 7th 03 08:25 PM |
Question ~ Does fuel injection add weight? | Barnyard BOb -- | Home Built | 0 | July 6th 03 09:47 PM |
