trailer wheels won't turn
Old June 17th 10, 06:01 PM posted to rec.aviation.soaring
Darryl Ramm
Default trailer wheels won't turn
On Jun 17, 8:47*am, sisu1a wrote:
* *In the dark of night I could not figure out if somehow the brake
shoes are suddenly rusted in place somehow or if the shock in the
hitch is jammed.
Behind the actuation rod are the 2 cables that go to the brakes. *It
seems that the problem from this point or beyond/behind.
I suppose it is possible there is a problem with bearings or that
somehow the brakes stayed partially engaged on my last tow.
Any suggestions on how to diagnose and fix it? / where to get parts.
Sorry to hear about your bad luck. No suggestions, other than go
electric since it will prolly cost less to switch over than to fix,
and you get MUCH better brakes out of the deal. That work normal in
reverse. And don't freeze up when not used for a little while. And
don't need to be babied/greased/talked nice too etc. *Should I change
my '10 reasons' to switch list my into '11 reasons' to switch to
electric brakes list? * *Nah, long term mechanical reliability is
already covered...
-Paul (eff surge brakes!) Hanson
Paul
Maybe one day you'll be maneuvering your trailer by hand on a gentle
slope and unable to control it and it will run over you. Then those of
us who like override brakes won't have to put up with your list
anymore ;-)
Where I keep my trailer in relatively dry conditions everybody leaves
the brakes on, the larger fear is the occasional strong wind, even if
the trailers are also chocked and well jacked. I've had several pilots
from the UK tell me that it is common at their clubs is to keep the
brake off because of this chance of seizure.
Darryl
Old June 17th 10, 07:07 PM posted to rec.aviation.soaring
Chip Bearden[_2_]
Peter's instructions are spot on. 1 & 2 might work. 3 WILL work even
if the problem is frozen cables or other parts of the mechanism, but
then you'll have to readjust the brakes to make them servicable for
driving. At least it should allow you to remove the drum for access to
the brake. I'm not sure it's corrosion in the brake mechanism that's
the problem so much as the shoes seizing/rusting to the drum over time
due to moisture. After too many first-flight-of-the-year sessions like
this, I no longer set the parking brake for long-term storage.
Chip Bearden (with experience on both Komet and Cobra trailers)
ASW 24 "JB"
USA
Old June 17th 10, 07:24 PM posted to rec.aviation.soaring
John Smith
In Europe where manual gearboxes are still popular, most people know
that leaving the handbrake on for extended periods is not recommended.
In the USA with their authomatic gearboxes, this knowledge seems to have
got lost.
Mostly the problem is not corrosion of the cable but that the brake
shoes tend to somehow get "glued" to the drum. Forcing your trailer
backward may loosen the brakes, if you can do so without engaging the
override mechanism. Otherwise you may have to open the brake drums and
losen the shoes by hand.
Trailer tires for old (1981) Komet Trailer [email protected] Soaring 3 May 13th 09 10:24 PM
Minden Trailer Dolly Wheels gfoster07k Soaring 3 September 19th 08 05:12 AM
Where can I buy wheels for a Cobra trailer? Eric Greenwell Soaring 5 April 28th 07 03:44 AM
Wheels [email protected] Soaring 7 October 19th 05 02:29 PM
Replacing Cobra trailer wheels samcgiltner Soaring 8 August 12th 04 07:46 PM
