![]() "Dudley Henriques" wrote in message ... On Jun 17, 2:44 pm, Mxsmanic wrote: GrtArtiste writes: Given this set of circumstances, what types of assistance would a commercial-rated pilot be able to offer assuming she is not rated on this type aircraft? I would guess-communications with ATC primarily. What else? The same things any non-pilot could do: move levers and buttons when the captain asks her two, read checklists, communicate with ATC, etc. It helps a bit if she has piloting experience, but that doesn't mean that she will be doing anything that _requires_ piloting experience. This is absolutely correct. At no time was this attendant actually flying this aircraft. She came up front and sat down in the right seat acting as an extra set of hands to select, push, pull, and turn, any and all switches and levers as asked for by the Captain. She acted as an "assistant" and that's all. Not to take anything away from this lady who performed as asked to perform under trying circumstances, and indeed she personally appeared on national TV this morning to "set straight" all the hype being presented about her acting in any other capacity than that I have stated above. It helped certainly that this nice lady had flying experience but it was by NO MEANS essential to what she was asked to do or what she actually did in the cockpit. Had the Captain opted to, he most certainly could have completed the flight to a safe completion from the left seat without assistance. He might have had to extend his reach a bit at times, but nothing earth shattering for sure. All in all, this was a class crew and they did a class job, right down to the stew who very classily and politely deflated the media hype on her role in the completion of this flight. Dudley Henriques I find it interesting that no one has raised the subject of CRM. This seems to be a great example of the PIC assembling and using effectively all the resources available. I am confident that the PIC would have received extensive CRM training which probably included dealing with similar situations. I suspect that the PIC provided the FA clear direction as to the tasks she was required to perform as well as carefully monitoring her performance in the same way that the regular co-pilot would be. The entire crew deserves a 'nicely done'. Happy landings, |
Pilot nearly crashes in IMC, Controller helps | pimenthal | Piloting | 32 | September 27th 05 01:06 PM |
Aviation Conspiracy: Toronto Plane Pilot Was Allowed To Land In "Red Alert" Weather | Bill Mulcahy | General Aviation | 24 | August 19th 05 10:48 PM |
2 pilot/small airplane CRM | Mitty | Instrument Flight Rules | 35 | September 1st 04 11:19 PM |
non-pilot lands airplane | Cub Driver | Piloting | 3 | August 14th 04 12:08 AM |
Home Builders are Sick Sick Puppies | pacplyer | Home Built | 11 | March 26th 04 12:39 AM |
