Co-pilot gets sick, stewardess helps land airplane
Old June 23rd 10, 09:39 PM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
Hatunen
Default Co-pilot gets sick, stewardess helps land airplane
On Wed, 23 Jun 2010 22:31:05 +0200, Mxsmanic
Virtually every pilot arguing about it here is a low-time private pilot. I can
spot them from a mile away.
And all of those lowtime private pilots can spot a non-pilot who
thinks he knows-it-all from a computer game a mile away.
[Mixie has a way of mixing truisms that hardly need stating with
assertions that come from his apparent thinking that a computer
game gives him life experience, and with assertions that rely on
believing that a PC game is the equivalent of a large
professional flight simulator.]
************* DAVE HATUNEN ) *************
* Tucson Arizona, out where the cacti grow *
* My typos & mispellings are intentional copyright traps *
Old June 23rd 10, 09:50 PM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
Mxsmanic
Hatunen writes:
Since they are not important, what they do or don't spot is irrelevant. They
are just noise.
Old June 23rd 10, 10:44 PM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
DEFINE LOW TIME PILOT????????????????????????
Old June 23rd 10, 11:11 PM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
Mxsmanic
writes:
Oo-wee-oo!
Old June 24th 10, 03:43 AM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
Wingnut
On Wed, 23 Jun 2010 22:31:05 +0200, Mxsmanic wrote:
Wingnut writes:
Experience driving versus never having sat behind a wheel should make
some difference. It's plain old common sense!
It makes a difference
Thanks.
There will be some commonalities.
Very little in common, and much of it too dangerous to use. For example,
the 747 has flight controls, and so does the Cessna
And here we have the Cessna strawman again.
I can spot them from a mile away. They're in the "danger zone" of
low-time pilots, where most accidents occur. Enough experience to feel
confident, but not enough experience to feel humble.
Orthogonal issue to the original discussion.
The results might be the same. The results for the pilot might actually
be worse if his experience encourages him to take risks that the
non-pilot would not (such as attempting to fly the aircraft by hand).
Do you honestly think someone with a *commercial* license won't typically
be well past that "not experienced enough to be humble" stage?
Except in your earlier, specific scenario of being talked through a
procedure from the ground, where anyone with basic comprehension skills
will probably do about as well.
The only viable scenario is one in which the pilot/non-pilot is given
instructions by a qualified third party.
In your ever-so-humble opinion perhaps.
Someone with piloting experience might more quickly be able to find and
recognize particular controls or instrument readouts though, and will
be able to understand a more compact jargon, so he may be a bit faster
though other than that only as good as the quality of the ground
instructions.
He might find the magnetic compass faster, and he'd recognize the yoke
and rudder pedals and throttles. Beyond that, nothing is really certain.
Er, horizon? Altimeter?
Old June 24th 10, 11:02 AM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
Mxsmanic
Wingnut writes:
Often, but not always. I've already mentioned Pinnacle Airlines Flight 3701, a
shining example of incredibly stupid pilots who had CPLs.
And there are commercial pilots with far less experience than that. Need I
mention Colgan Air?
Without instruction, a non-pilot--or a pilot without experience in type--would
be in very hot water.
That's probably what he'd be asking himself. The AI had pretty colors that are
easy to spot, but the rest is not so obvious. He might spot the standby AI and
altimeter, but those aren't the instruments to watch.
Old June 26th 10, 02:31 AM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
Wingnut
On Thu, 24 Jun 2010 12:02:30 +0200, Mxsmanic wrote:
Wingnut writes:
typically be well past that "not experienced enough to be humble"
stage?
"Often" is good enough for me.
type--would be in very hot water.
Nobody said otherwise.
that are easy to spot, but the rest is not so obvious. He might spot the
standby AI and altimeter, but those aren't the instruments to watch.
The last time I checked, the altimeter is quite important when flying
(and doubly so when landing!). The horizon is generally easily
recognized, typically to a first approximation a circle that's half blue
and half some other color. Important to know the plane's orientation,
both pitch and roll (while the compass gives you yaw, the third
rotational degree of freedom).
Pilot nearly crashes in IMC, Controller helps pimenthal Piloting 32 September 27th 05 01:06 PM
Aviation Conspiracy: Toronto Plane Pilot Was Allowed To Land In "Red Alert" Weather Bill Mulcahy General Aviation 24 August 19th 05 10:48 PM
2 pilot/small airplane CRM Mitty Instrument Flight Rules 35 September 1st 04 11:19 PM
non-pilot lands airplane Cub Driver Piloting 3 August 14th 04 12:08 AM
Home Builders are Sick Sick Puppies pacplyer Home Built 11 March 26th 04 12:39 AM
