Hatunen writes:
While a heavy jet is a big sucker with a very complex panel (although lighter aircraft are now sporting some pretty compicated-looking electronci panels now) the principals are basic for any one who has flown a plane for even a short time: keep it level except coordinated turns. To land glide down to near stall speed, flare at the runway apron and make it stall just as the wheels tough the runway. In an emergency, a person who isn't a pilot certified for the aircraft in question needs to use the automation, not take the controls manually. The latter can easily lead to disaster. The problem is that you need actual practice in an airplane in order to become good at handling the controls, or you need to find an expensive, full-motion simulator for the same purpose. Having experience in a vastly different airplane won't help you much. In contrast, anyone can fly with automation, as long as he has instructions from someone qualified. And cruise flight and landing are or can be automated in large jet airliners. So the logical thing to do with an underqualified person in the cockpit is to stick to the automation to fly and land the aircraft. Anyone can turn knobs and move levers, but most people require a certain amount of practice before they can competently drive a moving vehicle. If aircraft are similar enough, of course, this doesn't apply. One can fly one type of Cessna single-engine prop with only experience in other models, and not make too many mistakes (although retractable gear and pitch adjustments can complicate things). But these small aircraft and large airliners are not similar. Of course, that last part takes some real practice (I failed my first flight test on the emergency landing). I don't know if modern airliners can, as they say, land themselves, or at least if they all can. I m pretty sure that if the plane is set up to land itself it has to be at a runway set up for it. Large airliners certified for autoland (which means most airliners) can land themselves if set up to do so, at airports with the proper equipment (which means an ILS certified for the purpose, although in a pinch almost any ILS might suffice). Autolands are not the rule, but in a situation like the one under discussion, where the airplane might be flown by a non-pilot or a pilot who doesn't have experience in type, an autoland would be the safest option, as it requires nothing more than the aforementioned pushing of buttons, turning of knobs, and movement of levers. No manual flying skill is required, and manual flying skill is the one thing that you cannot provide to an inexperienced person in the heat of an emergency. |
On Jun 21, 4:24*am, Mxsmanic wrote:
Large airliners certified for autoland (which means most airliners) can land themselves if set up to do so, at airports with the proper equipment (which means an ILS certified for the purpose, although in a pinch almost any ILS might suffice). Autolands are not the rule, but in a situation like the one under discussion, where the airplane might be flown by a non-pilot or a pilot who doesn't have experience in type, an autoland would be the safest option, as it requires nothing more than the aforementioned pushing of buttons, turning of knobs, Yeah right, find the right combination of buttons AND push the button to talk to a person who may or may not be there to help you push the right buttons AND fly the plane until you get such combination of instructions into the MFD to set up for autoland. I BET YOU CAN'T. Oh wait, your vision is restricted to a 19 inch monitor, so yeah IN YOUR MSFS simulator, you have a better chance since you don't have a fear factor of losing your life. |
On Mon, 21 Jun 2010 11:24:45 +0200, Mxsmanic
wrote: Hatunen writes: While a heavy jet is a big sucker with a very complex panel (although lighter aircraft are now sporting some pretty compicated-looking electronci panels now) the principals are basic for any one who has flown a plane for even a short time: keep it level except coordinated turns. To land glide down to near stall speed, flare at the runway apron and make it stall just as the wheels tough the runway. In an emergency, a person who isn't a pilot certified for the aircraft in question needs to use the automation, not take the controls manually. The latter can easily lead to disaster. I so note further down. The problem is that you need actual practice in an airplane in order to become good at handling the controls, or you need to find an expensive, full-motion simulator for the same purpose. Having experience in a vastly different airplane won't help you much. Well, duh. It depends on what you're trying to do. [Rest of obvious stuff deleted] -- ************* DAVE HATUNEN ) ************* * Tucson Arizona, out where the cacti grow * * My typos & mispellings are intentional copyright traps * |
Pilot nearly crashes in IMC, Controller helps | pimenthal | Piloting | 32 | September 27th 05 01:06 PM |
Aviation Conspiracy: Toronto Plane Pilot Was Allowed To Land In "Red Alert" Weather | Bill Mulcahy | General Aviation | 24 | August 19th 05 10:48 PM |
2 pilot/small airplane CRM | Mitty | Instrument Flight Rules | 35 | September 1st 04 11:19 PM |
non-pilot lands airplane | Cub Driver | Piloting | 3 | August 14th 04 12:08 AM |
Home Builders are Sick Sick Puppies | pacplyer | Home Built | 11 | March 26th 04 12:39 AM |
