Co-pilot gets sick, stewardess helps land airplane
Old June 23rd 10, 01:18 AM posted to rec.aviation.piloting
Default Co-pilot gets sick, stewardess helps land airplane
Mxsmanic wrote:
writes:
True, and in most cases, if the aircraft are anywhere near similar, a reading
of the aircraft manual will suffice for that.
Why would reading the manual be sufficient, but simulation not?
There you go making stuff up again and misrepresenting what people have said.
What I said was "..if the aircraft are anywhere near similar, a reading of
the aircraft manual will suffice for that."
Where did I say anything about simulators?
But more to the point that you tried to diverge to, if reading the manual
is sufficient, why would you then need a simulator of any kind?
And I've actually done that, have you?
Yes, I have.
Are you deliberately lying or are you in another of your delusional states?
You have said time and again you have never flown any airplane, much less
a different model after a read of the manual for the new airplane.
And before you go off on some other tangent about how safe it is to fly
an aircraft one has never flown before based only on a read of the manual,
in both cases there was an instructor aboard and in both cases all the
instructor did was ask me to demonstrate things.
Jim Pennino
Remove .spam.sux to reply.
Pilot nearly crashes in IMC, Controller helps pimenthal Piloting 32 September 27th 05 01:06 PM
Aviation Conspiracy: Toronto Plane Pilot Was Allowed To Land In "Red Alert" Weather Bill Mulcahy General Aviation 24 August 19th 05 10:48 PM
2 pilot/small airplane CRM Mitty Instrument Flight Rules 35 September 1st 04 11:19 PM
non-pilot lands airplane Cub Driver Piloting 3 August 14th 04 12:08 AM
Home Builders are Sick Sick Puppies pacplyer Home Built 11 March 26th 04 12:39 AM
