On Jun 23, 7:42*pm, Mxsmanic wrote:
a writes: This is minor point, but anyone who thinks all sensations are identical in an airplane, the differences being most evident in larger ones, clearly does not understand the physics. An airplane is not a point mass. Movements such as turbulence are generally translational: everyone on the aircraft feels exactly the same thing. Rotational movements about the center of gravity of the aircraft will have magnitudes that vary with the distance from the CG, but passengers near the cockpit or the tail of the aircraft will feel sensations that are essentially identical to those felt by the pilots. In fact, on a 747, some passengers (often in first class) will feel movements of larger magnitude than those felt by the pilots. So I do understand the physics, and the fact remains that everyone on the airplane feels essentially the same thing. The notion that the pilots up front are riding a bucking bronco while the passengers sleep in comfort in the back is total fantasy. Airliners are flown with great attention to smooth rides and gentle movements. These rides and movements are just as smooth and gentle for the pilots as they are for the passengers. I can assure you I understand the physics quite well. |
a writes:
I can assure you I understand the physics quite well. I didn't ask. |
Pilot nearly crashes in IMC, Controller helps | pimenthal | Piloting | 32 | September 27th 05 01:06 PM |
Aviation Conspiracy: Toronto Plane Pilot Was Allowed To Land In "Red Alert" Weather | Bill Mulcahy | General Aviation | 24 | August 19th 05 10:48 PM |
2 pilot/small airplane CRM | Mitty | Instrument Flight Rules | 35 | September 1st 04 11:19 PM |
non-pilot lands airplane | Cub Driver | Piloting | 3 | August 14th 04 12:08 AM |
Home Builders are Sick Sick Puppies | pacplyer | Home Built | 11 | March 26th 04 12:39 AM |
