Co-pilot gets sick, stewardess helps land airplane
Old June 24th 10, 11:02 AM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
Mxsmanic
Default Co-pilot gets sick, stewardess helps land airplane
Wingnut writes:
Do you honestly think someone with a *commercial* license won't typically
be well past that "not experienced enough to be humble" stage?
Often, but not always. I've already mentioned Pinnacle Airlines Flight 3701, a
shining example of incredibly stupid pilots who had CPLs.
And there are commercial pilots with far less experience than that. Need I
mention Colgan Air?
In your ever-so-humble opinion perhaps.
Without instruction, a non-pilot--or a pilot without experience in type--would
be in very hot water.
Er, horizon? Altimeter?
That's probably what he'd be asking himself. The AI had pretty colors that are
easy to spot, but the rest is not so obvious. He might spot the standby AI and
altimeter, but those aren't the instruments to watch.
Old June 26th 10, 02:31 AM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
Wingnut
On Thu, 24 Jun 2010 12:02:30 +0200, Mxsmanic wrote:
Wingnut writes:
typically be well past that "not experienced enough to be humble"
stage?
"Often" is good enough for me.
type--would be in very hot water.
Nobody said otherwise.
that are easy to spot, but the rest is not so obvious. He might spot the
standby AI and altimeter, but those aren't the instruments to watch.
The last time I checked, the altimeter is quite important when flying
(and doubly so when landing!). The horizon is generally easily
recognized, typically to a first approximation a circle that's half blue
and half some other color. Important to know the plane's orientation,
both pitch and roll (while the compass gives you yaw, the third
rotational degree of freedom).
Old June 26th 10, 03:21 AM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
Mxsmanic
Wingnut writes:
It has not been good enough to prevent crashes.
It is called a _standby_ altimeter for a reason, although it presumably works
even when other instruments are working.
It's also important to know the current stall angle, the angle of attack, the
flight path vector, the airspeed and altitude trends, the V-speeds, the upper
and lower airspeed limits, the current track, the current route, the current
vertical profile, the current heading, the expected top of descent, and about
a zillion other things that a private pilot isn't likely to see in a tiny
Cessna.
Old June 26th 10, 03:46 AM posted to rec.aviation.piloting
george
Cessna.
Wrong again.
No matter what the aircraft is there are basics.
You demonstrate that you have terms which do not equate to what we
actually do.
Sure your word salad looks impressive but that's all it is just word
salad.
But if you had actually learnt to fly in a real aeroplane (even a
Cessna) you would know that
Old June 26th 10, 02:35 PM posted to rec.aviation.piloting
Mxsmanic
george writes:
It takes a lot more than basics to fly a 747. In a Cessna 152, there isn't
much else beyond the basics, but in a large commercial airliner, almost
everything is beyond the basics.
A pilot's license does not confer instant knowledge of all systems and all
details of all aircraft. A good pilot knows this.
actually do. Sure your word salad looks impressive but that's all it
is just word salad.
Not to a qualified pilot of the aircraft in question. In fact, almost
everything I named is on one or two displays in a large jet, and of course a
pilot of such is expected to know what they are and where they are.
Old June 26th 10, 11:10 PM posted to rec.aviation.piloting
george
On Jun 27, 1:35*am, Mxsmanic wrote:
george writes:
It takes a lot more than basics to fly a 747. *In a Cessna 152, there isn't
That is why we have ratings.
You -do- understand what I mean by ratings?
Old June 26th 10, 11:57 PM posted to rec.aviation.piloting
Mxsmanic
george writes:
How so?
Old June 30th 10, 03:24 PM posted to rec.aviation.piloting
George is right and YOU are WRONG. WRONG AND SO WRONG.
YOU really are CLUELESS about flying an airplane.
Tell this to Sully AND CREW who's glider rating got him to FLY and
LAND a large commercial airliner into the Hudson......
If my memory serves me correct the skies had a very loaded down glider
in the flavor of a 747 going through volcanic ash before they got
their engines restarted. Tell me, what kept that plane flying besides
the basic rules of flight????? LET ME GUESS, YOU WON'T answer.
Old June 26th 10, 08:27 AM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
JohnT[_3_]
"Mxsmanic" wrote in message
upper
current
about
Cessna.
But you know them all because you play a computer game?
JohnT
Pilot nearly crashes in IMC, Controller helps pimenthal Piloting 32 September 27th 05 01:06 PM
Aviation Conspiracy: Toronto Plane Pilot Was Allowed To Land In "Red Alert" Weather Bill Mulcahy General Aviation 24 August 19th 05 10:48 PM
2 pilot/small airplane CRM Mitty Instrument Flight Rules 35 September 1st 04 11:19 PM
non-pilot lands airplane Cub Driver Piloting 3 August 14th 04 12:08 AM
Home Builders are Sick Sick Puppies pacplyer Home Built 11 March 26th 04 12:39 AM
